Parking Brake parts -63 F100 4x4
While my truck looks a long way from being on the road, I'm actually getting close to the reassembly stage
With that in mind, I need to get my e-brake working. The problem I have is I have no emergency brake parts!
The handle in the cab is broken but I do have the cables. Just nothing at the rear drums.
I need all the parts for the e brake at the drums. I just have a cable hanging outside the wheel with a hole in the backing plate. No levers, springs, or whatever else is needed.
I think I know the parts numbers, but can't find them. Anyone with more knowledge or experience than I (that shouldn't be hard) that can help me out with this? I don't mind laying out some cash, I just need to find all the parts..
I THINK this is the list, and from what I've seen it looks like the 63 T-Bird used the same ones (?)
ND - Any Help?
C1SS-2A637-A - Lever RH
C1SS-2A638-A - Lever LH
C0AA-2A642-A - Link to primary brake shoe
C4UZ-2A601-A - Spring, Parking Brake Link
91A 2106 Retainer (Parking Brake Lever Pin)
34424-S Lock Nut (M84)
Thanks in advance!
ND - Any Help?
Thanks in advance!
I THINK this is the list, and from what I've seen it looks like the 61/62 T-Bird used the same ones.
C1SS-2A637-A - Lever RH Same as 1961/62 Thunderbird = Zero
C1SS-2A638-A - Lever LH Same as 1961/62 Thunbderbird = Zero
C0AA-2A642-A - Link to primary brake shoe Same as 1960/61 Galaxie = Zero
Zero: PartsVoice & rearcounter.
GREEN SALES CO. in Cincinnati OH has 4,820 = 800-543-4959.
Probably every FoMoCo Dealer in the US/Canada has these, same 1939 thru today.
C4UZ-2A601-A =
FREESE MOTORS in Monticello IA has 6 = 319-465-3541.
NOS PARTS LTD in Waxahachie TX has 11 = 972-937-2201.
KLIMESH MOTOR SALES in Calmar IA has 20 = 563-562-3241.
55753-S2 (replaced 34424-S7) =
GREEN SALES has 135.
For additional sources, type these 3 part numbers (no spaces or hyphens) into PartsVoice.com & rearcounter.com
Thanks for all the help!
I managed to find all the parts and have them on order.
The bad news is that I got to looking closer at my cables and they are messed up pretty good.
I found the 2 rear cables, but the front cable on the 4WD is different than 2WD, it's about 8" longer (88 7/16"). Part Number C1TT-2853-AB. Anyone know a source for that or someplace that can make them? So far, my interweb searches have turned up zilch.
Also think I found a brake lever handle that will work, so it looks like the front cable is the big issue now.
As always, Thanks!!
As always, Thanks!!
Ford replaced the original rear cables with shorter cables, and so the front cable was also replaced as it's longer.
If you look up the 2A635 rear cables, you'll see they were replaced, catalog also shows the replacement front cable: C1PZ-2853-A
But, you cannot use this replacement front cable with the original rear cables. All 3 have to be replaced.
This is the 3rd time today I've listed this same info for three different members with three different trucks in three different threads.
Notice in the parts catalog that the original rear cables (C3TZ-2A635-C) were replaced by different cables: C1PZ-2A753-A
Because these replacement cables are shorter (60"), the original front cable was replaced by a longer cable: C1PZ-2853-A
PARTS INTERNATIONAL in Farmers Branch TX has 2 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
MrQuick
06-25-2017 07:11 PM
willowbilly3
04-10-2017 04:43 AM
TheJunkMan
08-21-2016 07:43 PM
