Issues with Red Head boxes or not? A discussion - Page 6 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #76
Old 09-17-2013, 04:06 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Originally Posted by PROSTOCK View Post
I've got 45K on my RH box and no problems, fixed the issue and have been real happy. Sorry to see others not as lucky(?).
I need another for my '65 and was set on RH, maybe no?
Just another rebuilder, I would get one from the parts store for convenience.
  #77
Old 09-17-2013, 05:58 AM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
I am happy with my new one (warranty) my steering it tight now. That being said I did have one failure so I can't say if it was just a fluke or a problem until I put some miles and abuse on this one and see if it holds up. I about ran over the curb on my first test drive after install because sheesh the truck turned when I moved the steering wheel.
  #78
Old 09-17-2013, 08:14 AM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Great to hear! With as much slop as we seen in your last box I bet it is like a whole new truck!
Sloppy boxes are no fun! LOL
  #79
Old 09-17-2013, 11:53 AM
Quote:
  #80
Old 09-17-2013, 08:25 PM
PROSTOCK PROSTOCK is offline
PROSTOCK is gaining momentum as a positive member of FTE.
Quote:
OH yea? That's where I got the one I have now and the output shaft bushing / bearing is completely gone. Don't want to repeat that. This truck only sees about 500 miles a year, it's not like this box has a lot on it now. Lifetime warranty is great if you don't mind replacing it for a lifetime. I like one and done...
  #81
Old 09-17-2013, 09:43 PM
Oh yea? Christinas' Red Head went out in just a few months. I would spring for the lifetime warrantee myself. All you can do on those things is grind the worn parts down, add new bushings, replace the steel ***** and any other parts it needs. Redhead is just another rebuilder, oh! but they do paint the top red.
  #82
Old 09-18-2013, 08:00 AM
Snowseeker's Avatar
I'd like to rebuild my own, bore out the housing, install the bearing, new ***** and stuff, great fun!
  #83
Old 09-18-2013, 12:19 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Quote:
A new career in you future perhaps...
  #84
Old 09-25-2013, 03:30 PM
sammie0126's Avatar
I got my core back today on my warranty replacement and also got the email Harvey had promised. Now take it for what's it worth but at least he did send me a note on what they found.
<!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> In your case, there was a pin in the valve that came loose. That's what was causing the play.
Thanks,
Harvey
  #85
Old 09-25-2013, 08:03 PM
Snowseeker's Avatar
Quote:
If I could get 3-4 done per day maybe.
  #86
Old 10-01-2013, 04:57 PM
As a matter of fact:
http://www.ford-trucks.com/forums/11...rebuild-2.html
I personally wouldn't want anything in my cooler lines that could block up and stop flow.
Thanks a lot Andy, you jinxed me my magnafine is leaking in that exact same spot now,
  #87
Old 04-13-2014, 12:20 AM
Lance Helmert's Avatar
Lance Helmert Lance Helmert is offline
Lance Helmert has a good reputation on FTE.Lance Helmert has a good reputation on FTE.
So with no new posts I'm assuming the new box is working good? Hope it is. Would you buy another one? Thanks for all your helpful threads.
  #88
Old 04-13-2014, 09:56 AM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Since my second power steering pump, I've had no more woes. It wasn't a red head issue, just bad luck with the first ps pump.
  #89
Old 04-13-2014, 09:58 PM
rowekmr rowekmr is offline
rowekmr is gaining momentum as a positive member of FTE.rowekmr is gaining momentum as a positive member of FTE.
Where is a good place to get a PS pump? Ford, cheap parts outlets or another place?
Quote:
  #90
Old 04-13-2014, 10:44 PM
wpnaes's Avatar
I went to RockAuto, a sponsor here, but don't get the cheapest one there. Also ordered 2 new hoses, but not the hose to the reservoir.
Gear Box & Hose Replacement for Dummies sammie0126 Excursion - King of SUVs 80 01-16-2017 12:29 PM
Steering play mcornwell 1999 to 2016 Super Duty 1 10-02-2015 11:01 PM
Steering gear install 99expyTN 6.4L Power Stroke Diesel 4 10-28-2014 01:07 AM
Power steering leak & loose steering gudor 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-16-2014 03:26 PM
Red-Head install '05 Ex 6.0L and 2wd Misky6.0 Excursion - King of SUVs 2 02-18-2013 10:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
