85 6.9idi air issues??
i just bought a 85 4x4 4speed for $300 the guy said it didn't have compression, got it home and started fixing pices here and there, i believe i need new injector cap o'rings, i will not know if i need new caps or not till i pull them off and clean them up. i'm going to add clear 3/16 fuel line to check for air when i get that far. does anyone sell the o'rings or know what size they are? should i use viton o rings or??? it runs really rough but it sure turns over like it has compression. oh yeah, when i got it it didn't have a line from the filter to the ip..
im not new to diesels but i am only 18 so i have much more to learn
Any bearing house or auto parts store should the o rings, and yes, you should get viton, size 111. Most will tell you to get the complete kit, I'm cheap, I didn't. Iirc the kits cost 40/60 $, I spent less than $5, on o rings. Be really carefully getting them off and back on and you should be ok.
By the way, I'm 70 and I still have much to learn.
I got the new o rings installed to find out the return line is cut in half next to the transfer case and the flywheel ring gear is chewed up... I have a livestock show im going to till sunday so ill return working on it come sunday night, I think ill pull start it until I get it running and know I want to put a $30 ring gear on it and spend the 10+ hours pulling and installing the transmission
Fixed the return and noticed the coolent was low almost empty... so I was about to fill it and decided to check the oil... what do you know... I drained about 2 gallons of water out of my oil pan... my question is do I pull the motor and pull the heads off ormaybe expect a rebuold or a good 6.9l donor moto?
It could be cavitation, but there's a better chance it's just head gaskets. I'd pull the heads to check condition before making any decisions. On mine the head gasket damage was obvious:
Of course mine was a compression problem, not coolant.
I wouldn't worry about studs unless you're turboed or plan to add one later. In fact, if you do have a turbo I'd lean even more towards head gasket being your problem.
You may want to run a compression check before disassembling just to narrow it down some and to check the health of the engine.
ldsparamedic
10-21-2013 12:41 PM
LSO1123
09-16-2011 02:12 PM
mechelement
31
05-04-2010 03:48 AM
mv1967
03-29-2010 06:22 AM
