New Powermax Turbo, should I get Billet Wheel?
Old 09-07-2013, 06:42 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Originally Posted by hink10
Yes, the new gen 2 or whatever WW is a billet aluminum wheel. The one I'm looking at is probably made by the same manufacturer as the WW or at least the sale design.
IIRC Adrian has a new design wheel that's proprietary to MTW and built only for him. I'm fairly certain that's what the delay (in shipping) is/was. I was going to get a stage 1 turbo from him to drive to Smoke Show next week and DHL screwed the shipping up so no turbo to play with
Old 09-07-2013, 06:49 AM
raptor131's Avatar
raptor131
raptor131 is offline
Can u put it on yourself in your garage? Or is a special tool needed?
Old 09-07-2013, 06:53 AM
npccpartsman
IIRC you'll need a 12 pt. socket to take apart the turbo compressor housing bolts but no special tool to change the wheel. It's just a nut that may have been ground a bit on one side for balance. Just don't over tighten it when you put it back together. It's not hard to do at all.
Old 09-07-2013, 07:07 AM
Nice Work Truck's Avatar
Nice Work Truck
Nice Work Truck is offline
Yes and this should help a lot.
https://www.ford-trucks.com/forums/8...nuals-pdf.html
Old 09-07-2013, 10:13 AM
POORBOY1964's Avatar
POORBOY1964
POORBOY1964 is offline
Here is a little info on the single and duel plane wheels and what you get out of each.
who sells 03 wheel? - Ford Powerstroke Diesel Forum
Old 09-07-2013, 11:29 AM
hink10's Avatar
hink10
hink10 is offline
Apparently the order was in the DHL sent it back somewhere because there was a customs issue, probably DHLs fault. I know he has not happy because guys were waiting for turbos. That sucks you won't have the turbo in time. Regarding the wheel, I thought he said the fins were the same as the WW? we didn't get into that too much however.
Old 09-08-2013, 05:42 AM
HeavyAssault's Avatar
HeavyAssault
HeavyAssault is offline
Contact James at the link below. I don't know about current stock but he sells the same single plane billet compressor wheel for the Pmax. He can balance your assembly with the new billet wheel on his balancing machine. Since the factory balances your assembly don't you think it's smart o balance it with the new compressor wheel??
Barder Turbo Service - HOME
Old 09-08-2013, 12:20 PM
hink10's Avatar
hink10
hink10 is offline
Unfortunately I don't have the time to send to have rebalanced. Thanks for the info, that's good to know.
Steve
Old 08-13-2014, 03:49 PM
Sullid01's Avatar
Sullid01
Sullid01 is offline
So can I ask for some updates? What did you get? What's good, What's bad? If I need to take my turbo off, I figure this would be a nice addition. I was looking at the Riffraff one for the powermax.
Old 08-13-2014, 04:19 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
I have installed a few Powermax turbos with the billet wheel from Riffraff. Never had a customer disappointed. Clay is a sponsor here and has the best service I've found. Riffraff Diesel Billet Compressor Wheel 05-07 - Riffraff Diesel Performance
Old 08-13-2014, 10:02 PM
hink10's Avatar
hink10
hink10 is offline
I don't have much new to say, I would not recommend the Wicked Wheel Gen II however. The EGTs where high on the dyno. The tune helped and to be honest that's as far as I've taken it. I haven't towed so no issue yet. I just haven't had the time to pursue but I bet the wheel that came with the turbo would have been a better choice. The WW is a bit slow to spool but the turbo/wheel sounds pretty good. I may swap it out someday, will post if I do.
Go with a turbo/wheel that guys have used and is tested to be efficient. I was in too big of a hurry and made the wrong choice. The Excursion still goes pretty good however! If anyone uses different wheels with the Powermax turbo, please post results! Good luck!
Steve
Old 08-14-2014, 04:34 AM
Nice Work Truck
I got my billet wheel for the powermax from MTW and like it a lot.
  #28
Old 08-14-2014, 10:04 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Clay's wheel is also $60 cheaper.
Did a review on it not too long ago: https://www.ford-trucks.com/forums/1...el-review.html
Funny you should mention the slow spooling....
My buddy had one on his '07 F350 and he kept complaining about his Powermax being slow to spool. I honestly thought he was being unreasonable, but I guess he wasn't after all becuase he always said my stockl turbo boosted and responded better than his Powermax and our engines were very similar.
Both had Atlas 40 and SRL+, I ran Clay's billet wheel, he ran Bob's WW2, stock turbo VS Powermax.
  #29
Old 08-14-2014, 11:22 AM
merc82's Avatar
merc82
merc82 is offline
I have a SP MTW billet wheel on my Powermax and they go together like peas and carrots. I would not run one without it. Really woke it up in low RPMs.
  #30
Old 08-16-2014, 07:47 AM
npccpartsman
What about the kits from Nate and Charlie? How are those working out, have you heard?
Quick Reply: New Powermax Turbo, should I get Billet Wheel?
