RedHead Group Buy Activated for Sep 11-13
The group buy is active. Call Red Head Wed-Fri next week and order your steering box.
https://www.ford-trucks.com/forums/1...l#post13507934
Ok boys and girls the group buy has been activated.
IMPORTANT: For you to get the group buy pricing, you need to call in your order Wednesday Sep 11 through Friday Sep13 - before or after and you may not get the discount. Call Red Head to order your steering gear box Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA and make sure to mention the FTE group buy.
Discount structure (RedHead will price with a $30 discount but if we end up with over 15 orders, they will credit each buyer after the group buy has ended):
5-15: $30 off
16-25: $40 off
26-35: $50 off
36>: $60 off
A few special notes to order the right box:
1997 F-series you need to let them know if you have a 2-bolt oval cover or 4-bolt square cover.
1999-2000 F-series and on 2000 Excursion, you need to count the splines on the box.
2008 F-series you need to let them know the production date of your truck.
For everyone else there is nothing to do but to order for your vehicle.
Don't forget, the group buy is activated for Sep 11-Sep 13.
5-15: $30 off
16-25: $40 off
26-35: $50 off
36>: $60 off
Don't know how to link on here yet so just a copy and paste, looks like several options but I've not found one thread saying yes I've used it......... Agrperformance.com here is the paste
AGR Performance has released a line of new steering components for the Ford Super Duty trucks and SUV’s featuring power steering pumps built using the time proven AGR P-series Super Pump. This pump design has proven itself in nearly 40 years of use on GM, Dodge and Jeep trucks and SUV’s. We start with the AGR P-series Super Pump which is then modified and an adapter bracket added to allow it to bolt into the stock Ford mounting position. The AGR Ford Super Pump develops 1500 PSI and will flow 4 _ GPM, a substantial increase over OEM specifications. The AGR Ford Super Pump provides increased turning force and improved steering reaction. The increased flow and pressure also eliminates the loss of power assist when braking on Power - Boost brake equipped vehicles.
AGR Performance also manufactures an improved steering gearbox and the famous ROCKRAM® System for the Ford Super Duty. The AGR premium remanufactured steering box is more than just an auto parts store rebuilt gearbox. We begin by inspecting and testing all individual components.
Proprietary modifications are made to the housing and valve assembly to provide increased flow capabilities, allowing the box to react quicker (when used in conjunction with the AGR Ford Super Pump). All new bearings and seals are installed and an attractive satin gray finish completes the package.
Magnus E
09-07-2013 07:32 AM
