460 efi to carb conversion
has any one succesfully converted an efi 460 to carb? i know there are adapters available to put a carb on the efi manidold. what else did you have to do to make it work? is it posable to put a mechanical pump on it or did they remove the stuff for that when they whent to efi?
on
The following users liked this post:
Plenty have converted to carb, but why do you want to. Is yours running rough or not at all. Are you hoping for more power.
What's the overall goal for doing this.
Trans control for e4od is the biggest issue. You can retrofit tps to the carb and hope the trans is ok with the different power delivery, or buy the trans controller you can tweak, but you still need all the sensors.
Manual trans and c6 is easy and don't require that crap.
Fuel can be as simple as a return regulator on existing fuel lines and wiring pumps to power all the time, or I like to use an oil pressure switch with a bypass button just in case I need to prime the carb without cranking engine (and safer to not run pump without engine running)
Easy then
Buy the price Motorsport carb adaptor
Buy the one wire hei distributor, remove stock coil, attach green wire to coil- of new dist and red wire to + or batt of new dist
Hook up a 4psi return style regulator to existing fuel lines
Add oil pressure switch to activate stock fuel pump relay.
LEAVE ALL OTHER WIRING ALONE DO NOT CUT ANYTHING
Here's where I got the HEI distributor I have on my Bronco.
Performance Distributors « Performance Distributors
quadracer173
57
12-18-2021 08:41 PM
coffmajt
30
01-06-2014 09:07 AM
xavier23
15
01-08-2013 02:29 PM
rangergirl94
15
03-22-2012 06:20 PM
