Brake fuse keeps blowing.
My wife's 96 Expedition has suddenly been blowing the #13 fuse which operates the brake lights. I have checked all the bulbs to ensure they are seated good and they appear to be. I have also replaced the brake switch on the pedal but still blowing fuses. It has a towing hitch and everything looks good there. Has anyone had this problem? Thanks for any info.
Is there any other operations on that fuse slot and does it happen immediately after applying the brake?
Wait until the wife blows a fuse, then it will really hit the fan!
If the fuse blows ONLY when the pedal is pressed, then you've got a short circuit in the stop lamp circuit (only). That's sometimes (rarely) a shorted bulb, but it it's usually due to a wire having damaged insulation that allows the conductor to short to chassis.
Any specific event that happened immediately prior to the failure? (Rain, accident, repair, modification, etc.)
Do you live in a rural location (critters love to chew!)?
Besides the airbags, any other operational, electrical, or mechanical symptoms?
carrfamilynj
Electrical Systems/Wiring
03-03-2007 11:26 AM
