clutch sizes 10.5-11inch? - Ford Truck Enthusiasts Forums
Old 09-05-2013, 09:44 PM
tfmech tfmech is offline
tfmech is starting off with a positive reputation.
Here is my question can you use either 10.5 or 11 inch clutches with the same flywheel and bell housing? Will they both bolt on to the same flywheel? If not is there a way to tell which one I have in my 70 highboy without taking it out and measuring it?
Old 09-06-2013, 04:59 PM
Freightrain's Avatar
Freightrain Freightrain is online now
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
If it's a big block, it is most likely 11", even the 302 in a truck back then had an 11".
Can't speak for certain, but likely a stock flywheel will not have dual patterns. The 184 tooth flywheel was 11" clutch. The 157 tooth was 10 1/2" clutch.
Old 09-07-2013, 04:42 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Going from memory 300,302,360 all had 11". 390 had 12". If I am wrong NumberDummy will chime in when he catches this thread.
Old 09-08-2013, 11:35 AM
orich's Avatar
orich orich is online now
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
most newer flywheels are double drilled for 11 or the 11.5 clucth. 390 truck 11.5 that i've come across. Way back in the early 60's had car with a 1962 HP-390with a 12" clutch tho.... orich
10" to 11" clutch 82fordowner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 06-23-2016 04:15 PM
Any reason why you can't make this change?? Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 12-17-2015 11:05 AM
What kind of clutch? Andy_F100 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-15-2015 06:46 PM
Clutch/Flywheel Troubles with 1987 6.9 Bob Shumway Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 12-03-2014 05:08 PM
1970 Ford 302 Flywheel rangerottis Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 05-23-2014 04:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
