How to install fast idle control?
Old 09-05-2013, 05:50 PM
rhtrigger's Avatar
rhtrigger
rhtrigger is offline
I have an '05 6.0 with cruise control. Is there any way to implement a high idle option on this truck using the cruise control? What about aftermarket options to accomplish this? Thanks
Old 09-05-2013, 05:54 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Old 09-05-2013, 07:33 PM
99ExpyProblems's Avatar
99ExpyProblems
99ExpyProblems is offline
I know you said that you want to use the cruise control, but I used upfitter switches when I did mine. Bought them off of eBay for $145.00 free shipping and no tax. Found out later it would have been cheaper to just buy two parts, instead of the 'kit' that came to me because I have the OEM brake controller and didn't need the tray.
I used the purple and light green wire for mine and Aux4 of the upfitter switch.
Followed this writeup which is 1000 times better than any I found on the internet.
http://www.dfuser.com/Install%20Guides/Ford%20Upfitter%20Switches.pdf
Old 09-05-2013, 07:40 PM
99ExpyProblems
Also, I saw this before buying my upfitter switches. This guy used the parking light switch to do it. I can't vouch for it. I preferred to go with a relay for mine using the upfitter relay and switch setup.
Old 09-05-2013, 09:19 PM
Mr.Nobody's Avatar
Mr.Nobody
Mr.Nobody is offline
Is this the same even for excursions? For some reson I have it in my head that excursions have different wiring. I'm amazed that it just takes a single wire to make this happen.
Old 09-05-2013, 09:34 PM
99ExpyProblems
Not the same, but it can be done.
https://www.ford-trucks.com/forums/7...-idle-mod.html
Old 09-07-2013, 03:25 AM
burkeiceking's Avatar
burkeiceking
burkeiceking is offline
Do you have the upfitter switches? I just did the same thing on my F250.... There's a terminated wire in a factory taped wire in the area kinda behind where the upfitters would be, at least on the pickups. I believe it was a purple wire. I tied it in to my upfitter, now I idle at 1200 rpms, if the e brake is set and the upfitter is on. There's a YouTube on it, I couldn't post the link though
Old 09-07-2013, 03:32 AM
burkeiceking
If you need to know EXACTLY which harness and which wire it is let me know and I can look at my truck and give you exact directions, it took about ten minutes to do mine.
Old 09-07-2013, 05:34 AM
burkeiceking
Never mind me, 99Expy knows what he's talking about, thats a very good link he shared above. the wiring is all different....since the Superdutys had a PTO option, they were set up with these other leads straight off the PCM, the X never had a PTO option, thus no wires. I verified this on my buddies X.
gwcon
6.4L Power Stroke Diesel
15
03-23-2014 01:13 PM
Gr8ride
03-03-2012 08:23 PM
94F350IDI
01-25-2010 10:01 PM
grouch
15
12-04-2003 07:45 PM
Quick Reply: How to install fast idle control?
