Crate Engine
If long block, I would check if seller would let me fill with fresh oil, use an oil pump primer tool to check flow thru oil passages; especially thru the rocker arm assembly, then check if crank turns. If all checks out I would make an offer considerably less than cost to seller. Not an authority but would assume if there were going to be any issues as a result of setting it would be at the top end which could be rebuilt relatively cheap???
JimNolan
09-23-2005 05:33 AM
RNMCGUIRE
12-10-2002 08:16 PM
