1949 F1 Gas Tank - Ford Truck Enthusiasts Forums
1949 F1 Gas Tank
Old 09-05-2013, 11:24 AM
dferrell5 dferrell5 is offline
dferrell5 is starting off with a positive reputation.
1949 F1 Gas Tank
I am researching information regarding gas tanks as I want to relocate mine to under the bed of the truck. For those of you that have made this change, could you please advise on anything I should be aware of or on the look out for regarding buying a gas tanks. Would be really greatfull if you could share what tank you used in your bulid and why.
Old 09-05-2013, 02:18 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Derek,
We used a 1970 22 gallon Mustang tank. This increased our range by 40% or so vs. stock - nice. It fits out back under the bed with the fill spout through the bed. Jniolin has a nice write- up on the installation. You have to build a little rack for it to sit in & in our case we had to move one bracket under the bed to get enough room.
We got our tank from Rock Auto for about $120. Then you get the sender unit for that tank as well. The tricky part for us was that we modernized our gauges & they all used a ohm - 200ohm range for full to empty. The mustang sender unit used some other scale like 11ohms to 78ohms.
Eventually we bought a modern universal sending unit & welded it on the
'70 sending unit & everything works fine.
Good luck over there in San Antonio.
Ben in Austin
1950 F1
Old 09-05-2013, 03:41 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Before you decide on a gas tank behind the rear axle, plan out your exhaust routing. If you want a rear exiting exhaust, the rear tank can be a problem. On my 49 I am staying with the original tank since I wanted a rear exit exhaust. I suspect many go to a side exhaust when using a rear, between the frame rail, tank. Depending on your rear axle choice, you can get space constraints for rear shocks. Lots to consider when you make a change!
Old 09-05-2013, 04:02 PM
ben73058's Avatar
Hey Derek,
Bill is correct in highlighting that when you make changes it generally effects other things as well - tradeoffs. We like the bigger tank out of the cab & out back under the bed - but we had to go with side exit exhaust. You also have to change the shock perches to fit around the tank - but it's not a big deal to move them & weld them back in. After some complaints from the female side of the family I also added a charcoal filter to reduce the gas tank venting fumes in the garage.
This project is a (1) or (2) weekend job - I'd say a more than one six pack job.
Ben in Austin
1950 F1
Old 09-06-2013, 01:21 PM
49Willard
If you kept your tank in it's original positiion, do you have any issues with the tank venting fumes/smell of gas into the cab?
Old 09-06-2013, 01:32 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Unless you have a leak, or are sloppy when fueling, there should not be any fumes in the cab. The disadvantage to the cab mounted tank is it steals a couple inches of legroom. Removing the tank from the cab allows the seat to go back further, and/or gains storage space.
'92 F150 fuel system problem banjobrad05 1987 - 1996 F150 & Larger F-Series Trucks 3 03-23-2016 03:48 PM
Gas tank for a Supercab? kadrocker 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-06-2016 08:44 PM
51 F1 fuel tank re-conversion farmall_7 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-31-2015 10:59 PM
New gas tank of 79 F100 Turtle Carton 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-07-2014 10:01 AM
1967 Ford Ranchero Gas Tank Cantaloupes Ranchero & 1961 - 1967 Econoline 4 02-28-2014 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
