Tailgate Window Stopped Working Again? - Ford Truck Enthusiasts Forums
Old 09-04-2013, 09:27 PM
Built-Ford-Tough91 Built-Ford-Tough91 is offline
Built-Ford-Tough91 is starting off with a positive reputation.
So my 1991 bronco is having problems with the tailgate window again. It had stopped working for a while, so I replaced the motor. Then the window worked for 3 days but it stopped and now its stuck. I've tried both the keyhole and the switch so it's not that. Could it possibly just be that I need to grease the motor with some wd40 because the gears locked up or could it be something more complicated?
Old 09-05-2013, 05:20 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
Have you tried the key while pushing the tailgate to be sure the safety switch is engaging? Are the plastic bushings on the striker bolts good?
Tailgate Window Lift Key Switch Bypass? 78Ranger_Bronco 1978 - 1996 Big Bronco 26 05-19-2016 03:47 PM
Tailgate window issue bbygirl778 1978 - 1996 Big Bronco 3 10-03-2015 02:42 AM
Power window problems teamlx88 1997-2006 Expedition & Navigator 9 05-21-2015 08:30 AM
'85 Bronco tailgate window issues with unique workaround js.baker09 1978 - 1996 Big Bronco 19 08-27-2014 01:22 AM
Bronco tailgate motor fordka 1987 - 1996 F150 & Larger F-Series Trucks 4 06-25-2014 03:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
