272 Valve Adjustment Help - Ford Truck Enthusiasts Forums
Old 09-04-2013, 04:39 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Hey guys, I'm going to adjust the tappits on my 1955 272 heads. It's a car engine if that matters. I have seen several suggestions for adjustments. If doing the adjustments cold, what should the intake and the exhaust valve adjustment be? Are they the same? Some sources say yes, while some say no. It would make sense to have the gap on the exhaust be wider because of thermal expansion. Any suggestions?? Jag
Old 09-04-2013, 05:02 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
On a stock motor, they should be adjusted the same. I think it is .019" cold and .018" hot. With stock rocker arms, an easy way to do it is to turn the screw until there is no clearance and then loosen it 1/4 turn. That will be about .019"
Old 09-04-2013, 10:40 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
I always set mine at .019 hot, don't know what the cold setting is..
Jag IFS......Anyone have one completed in a F1? rpol7966 1948 - 1956 F1, F100 & Larger F-Series Trucks 69 05-06-2015 11:31 PM
272 Valve Adjustment Help Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 08-31-2011 05:07 PM
Spark Plug Question Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 6 08-18-2010 11:17 AM
Tappet Adjustment on my 272. Help Jag Red 54 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-06-2005 10:54 AM
272 Y-block Tappet Adjustment help Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 04-06-2005 10:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
