Possible 292 purchase.
Old 08-31-2013, 09:18 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I'm building up my '59 F100 with a 223 to start with. But I located a 292 & 4 sp from a '60 truck. Is there a source to help me ID heads and block by casting #'s? The engine & trans (on local CL) appears to be complete from w/pump to carb to shifter, the whole schmear. I also see that T bird dual exh manifolds are readily available on Fleabay for a reasonable price. Is there any steering gear clearance issues using these?
Now for the meat & spuds part: I plan on having Sunwest engine and machine in Medical Lake, Wa rebuild it (close proximity and 5 star rep). I'm looking at building this one to haul a 19' 5th wheel. I'm thinkin a 4 degree cam advance, T-bird exh mani's, dual exh w/ Xover and a motorcraft 2100 from a 360 that I have (Packrat syndrome). Naturally a smokin' dizzy and coil. Think this would get me the torque I want? I'll be running 3.50 gears to start and maybe switching to 3.33's
Any obvious things to look at when examining these engines? I know the basics; looking for any specifics to these engines.
Thanks in advance. BTW I will be starting a thread in the Fridge forum on the exh
Old 09-01-2013, 12:14 AM
Y-Blockhead's Avatar
Y-Blockhead
Y-Blockhead is offline
Look on John Mummert's site for just about anything you want for a Y-Block including performance parts and block/head ID TECHNICAL
Old 09-01-2013, 01:32 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
I'm building a 292 with a zero-decked block, -113 heads, balanced rotating assembly, and an Isky "E4" cam. I'll advance the cam a couple of degrees for improved torque at low/mid RPM. Of course, this will cost high RPM performance and peak horsepower. Exhaust is Red's stubbies with ceramic coating. Mummert intake and Holley 1848-1 carb. That's plenty of carburetor for a street 292. Well, it's bored to 301, but still plenty of carb.
BTW: This beast is going into Albatross. That's our '55 F500.
Sure will be able to haul a load.
Old 09-01-2013, 08:52 AM
46yblock's Avatar
46yblock
46yblock is offline
Dual exhausts from a T bird wont work. You will need Rams Horns.
Old 09-01-2013, 12:38 PM
Y-Blockhead
Curious way you chose this model 4160 and not one with an electric choke? With the Mummert intake and headers you have no way to connect the "Hot air choke".
Yes I know there is a electric choke kit available but at extra expense.
Old 09-01-2013, 09:04 PM
The Horvaths
I live in Dallas, TX. It's often really hot here. I'm also never one to run with the pack either. Therefore, I have deliberately put a manual choke on it. I carefully chose it (the 1848-1) after digesting Ted Eaton's carburetor shoot out.
I'm still toying with the idea of incorporating a hand throttle! Because I'm just that way.
By the way - very good observation. You know your stuff!
Last edited by The Horvaths; 09-01-2013 at 09:05 PM. Reason: Clarification. Ad nauseum..
Old 09-02-2013, 06:28 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I decided to run the ram horns on this. Picked it up today. It ain't stuck, had oil in it with no coolant and still had some coolant in it that was green and slick. Looks to be rebuildable. I'll know more when I get the heads off. BTW it also has the late 2v manifold. So I'll most likely run my 2100 carb that I know is good
Old 09-02-2013, 06:59 PM
46yblock's Avatar
46yblock
46yblock is offline
Yeah 2100s are good on 292s if they have 1.02-1.14 venturi's.
Old 09-02-2013, 07:28 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
thanks for the tip. I'll look to see what they are. The ram mani's may require a bit richer, but I'll try it first.
Old 09-02-2013, 09:07 PM
The Horvaths
Start small and you can always work up. An over-carbureted engine is always a disappointment.
Old 09-02-2013, 09:36 PM
46yblock's Avatar
46yblock
46yblock is offline
Ditto! A 1.21 or 1.23 venturi carb will make for high rich idle, and poor low in throttle response, and bad gas mileage. The 2100s were not universal in application. Rams Horns wont dictate much of anything regarding carburetor size, type or tuning.
Old 09-02-2013, 09:42 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
The carb on it now is a Holley 2V. I haven't dug into it yet, but the throttle shaft has zero play and it's free. That's always a good sign. Think I'll get it off tomorrow and stick it in the carb clean.
And yes, I've made the too big carb mistake. I'm looking for torque as I also have a line on a 19' Scamp 5th wheel.
Old 09-02-2013, 10:54 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I give up, where do you find the venturi size on these 2100's? Took the top off and took the venturi cluster out, didn't see nuttin'. Tag # DOTF R b 9j 15
Found it on the side of the carb. It's a 1.23. Man, I wish these forums were around when I was younger. Woulda made a bunch fewer mistakes. Oh wait, I was a kid who knew everything....................
Old 09-02-2013, 11:25 PM
Y-Blockhead
I just wish I could remember everything I knew when I was a young know-it-all so I didn't have to re-learn it now.
Old 09-02-2013, 11:32 PM
Y-Blockhead
Quick Reply: Possible 292 purchase.
