help identify paint color - Ford Truck Enthusiasts Forums
Old 09-04-2013, 01:36 PM
chris989 chris989 is offline
chris989 is starting off with a positive reputation.
Hello all,
I thought my truck was medium copper. It was what the PO said in conversation. He may not know as the truck was gifted to him.
On my door panel i have only the #2 in the color digit. When i look at 1978 Color Codes - Ford Truck Paint Cross-Reference everything is 2 digits, and medium copper begins with an 8 (second page)
Could it be Coral 2A???
Can anyone help identify this truck? I wanted to paint another project to match.
Chris
Old 09-04-2013, 02:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
In 1978 color code "2" meant "medium copper". All Ford color codes were single digit one color, two digits meant it was two tone, first digit primary color, second digit accent color.
Looking at your warranty plate, it looks like your truck has been repainted.
It looks like there is a masking tape line on the very top edge of the plate.
I would look into some hidden areas to see if the paint is the same, behind the door panels, under the carpet, up under the dash, etc.
Just so you know, in '78 color code 2 on an Econoline meant Tangerine. I think that's closer than medium copper.
If it's a stock Ford color, it could be "Y" which is "orange"
Really nice looking truck by BTW.
Old 09-04-2013, 02:21 PM
mikeo0o0o0's Avatar
Here's a '73 Explorer color code "Y" orange.
Old 09-04-2013, 02:48 PM
The exterior has been repainted but the interior of the cab has not. Did you get a chance to look at the website? None of their numbers match..
I can always buy a 1/2 pint to test.
Chris
Old 09-04-2013, 05:40 PM
mikeo0o0o0's Avatar
Chris
Are you sure about the interior not being repainted? Like I say, it looks like the jamb section of the door has been repainted and that usually means the interior, at least jambs and inside of the doors, has also been painted.
I didn't look at the link because I use the Ford factory parts catalog to look up the color codes.
I've seen aftermarket color charts use two digits to indicate a single color before, Ford didn't do that. Like I said, if there are two digits in your color code then the truck was originally two tone from the factory. I looked up the 2A code that the chart says is coral. In the catalog 2A means it would have been a two tone that was "medium copper" main color and "black" secondary color, not a very good combination in my opinion.
I really think that if you pull a door panel or lift up the carpet you'll find its copper underneath.
I did go to the color chart you linked and none of those codes match anything the factory used for the trucks.
Old 09-04-2013, 07:38 PM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
In the top picture it looks exactly like my 77 which is coral.
Well, my cab is anyway.
Old 09-05-2013, 11:10 AM
I splurged and bought a few 1/2 pints yesterday and shot some color. This is just over the unprepped original yellow paint so it does have bleed through. But it gives the idea.
The ford in my post is certainly Medium copper, here is the original factory chip held against ditzler paint code 2880
Here is the 73 Y code, it is Burnt orange ditzler code 2576
Old 09-05-2013, 11:21 AM
mikeo0o0o0's Avatar
Hmm?? I would've thought medium copper would have been more copper than orange.
Learn something new every day.
skyjacker failure chris989 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-06-2016 02:04 PM
high pinion 60 chris989 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-27-2014 04:14 PM
super cab vent windows chris989 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-02-2013 01:44 PM
HP 44 leak chris989 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-26-2013 04:21 PM
6 inch lift bump steer chris989 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-14-2013 03:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
