1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
DPF Delete pipe and still regenerating??????
Old 09-03-2013, 06:43 PM
Strokin82's Avatar
Strokin82
Strokin82 is offline
I have a 2008 F350, when I purchased the truck it came with an edge performance tuner and a DPF/Cat delete pipe. All sensors for DPF are placed in the delete pipe. About 3 weeks ago it started regenerating and has continued to do so.
I have unplugged the sensors and checked connections, removed pressure sensor and cleaned. Im not sure what else I can do. If I have to start replacing sensors, I will just get a spartan tuner that can turn the regen off.
Any ideas guys???
Old 09-03-2013, 07:19 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
from what i have read, when the dpf is removed and the truck doesn"t have an offroad tune, you problemis what happens. Someone correct me if I am wrong here. Either you need to put the dpf back on, or get an off road tune.
Old 09-03-2013, 07:25 PM
BigOl04's Avatar
BigOl04
BigOl04 is offline
i watched a video from powerstrokehelp and he did a video on the DPF.. He stated that he recomended a certain tune that some aftermarket tuners would still regenerate.. I am crunched for time at work. someone with some time post the video for me please.. he goes into great detail on it..
Old 09-03-2013, 09:14 PM
07XLN's Avatar
07XLN
07XLN is offline
It you remove the dpf you have to tune it out. Edge tuners don't do this. Spartan and H&S are the only two that do
Old 09-03-2013, 10:04 PM
Strokin82's Avatar
Strokin82
Thanks, If I get a spartan tuner, it should take care of that
Thanks, I will be looking for that video
Yea, I called the Edge performance techs when it started, thats what they said BUT... I "think" that most DPF deletes just call for you to disconnect the sensors and leave them in the DPF assembly. In that case you would definitely have to get a tuner that tunes them out because they would not be able to be read at all....
The delete pipe that is on my truck has 4 sensors that are plugged in and screwed into the pipe. 3 probe looking sensors and something that looks like a pressure sensor spaced out where the DPF and the Cat was. Correct me if I am wrong but with those sensors there, they should be reading open flow!? Right??? So the regen would not have a reason to start or continously cycle.
Old 09-04-2013, 09:06 AM
donovan's Avatar
donovan
donovan is offline
Regen
The engine will still go into regen with a open exhaust. I think it goes into regen every 600 miles.
Old 09-04-2013, 09:13 AM
Strokin82's Avatar
Strokin82
Any idea why it is continuously doing it? Has been for the last 2-3 weeks. It will stop, then about 50 miles later it does it again.
Old 09-04-2013, 09:45 AM
donovan's Avatar
donovan
donovan is offline
Same problem has happened before
Its not seeing the exhaust temps it needs to start the regen. So it never leaves. Also the EPA wants you to have a DPF. I hope you have one. If not get one from a junk yard.
You can get a turner that will do a DPF delete or a New/Used exhaust system.
Old 09-04-2013, 10:07 AM
Strokin82's Avatar
Strokin82
I was thinking about getting rid of the Edge that came on it and getting a Spartan Tuner along with a EGR delete kit. Looks like that's what I'm going to have to do. I have a buddy looking for a DPF for me, he is in the junk yard business. It want be going on unless I have to though. Thanks for the info!!
Old 09-04-2013, 10:28 AM
donovan's Avatar
donovan
donovan is offline
DPF
It a GOOD idea to keep a factory exhaust system if you find one. Because of state inspection. Remember the DPF is mandated by the federal government and most states. I got burn on my 95 Camero when my county started smog testing. So if you can keep the parts to pass inspection I would.
Old 09-04-2013, 11:47 AM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Stay away from that power stroke help video guy. He's an idiot. I used to watch his videos but the crap he seemed to be spewing turned me off him.
Old 09-04-2013, 12:56 PM
Strokin82's Avatar
Strokin82
Yea, that is the plan
Old 09-04-2013, 01:01 PM
Strokin82's Avatar
Strokin82
I agree... I seen a video of his today, didn't really catch my attention...
Old 09-26-2013, 08:19 PM
Strokin82's Avatar
Strokin82
Thanks for all the replies guys. I recently received my Spartan tuner and love it. It obviously fixed my problem. I have only had it set as high as the +125hp tune, I am kinda hesitant about turning up any higher, thinking stuff might start breaking....lol
I also ordered the EGR delete kit but I haven't installed it yet.
But thanks again for you guys responses!!!
Old 09-29-2013, 12:26 PM
JR58's Avatar
JR58
JR58 is offline
Not trying to hijack a thread, just a question. With the Spartan and a delete pipe have you detected gains in fuel mileage?
Quick Reply: DPF Delete pipe and still regenerating??????
