SLR XXX +Atlas 40 = 16.2mpg in town!
Old 09-22-2015, 07:24 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
Yes...
Loaded those tunes out of curiosity and am surprised.
Shifting is really good, no flair on 3-5 and a little more smoke when you nail it... but power is great and mileage is as good as I'm probably going to ever see.
Anybody else see this?
Old 09-22-2015, 08:30 AM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
My mileage didn't change better or worse. I average about 15 mpg with mixed town and hwy. It is definitely smokey when you romp on it... (SRL+ Atlas 40) I know, I'm asking for it...
Sure is fun to drive tho!!
Old 09-22-2015, 08:52 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
SLR+ w/Atlas 40 gave me solid 15 in town. Smokey as well, cleared pretty fast, truck was fun. But with this tune... bigger smoke cloud and a little more fun, actually have to be careful taking off or it spins and wet roads, even light throttle will spin.
Old 09-22-2015, 05:48 PM
PA_Robert's Avatar
PA_Robert
PA_Robert is offline
damn....that's good
Old 09-22-2015, 06:05 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Originally Posted by PA_Robert
damn....that's good
Yep....
bad for tires!
Old 09-22-2015, 08:37 PM
acf6's Avatar
acf6
acf6 is offline
i see you made the comment of no 3-5 flare...that was why i got rid of my srl+. only tune i had that consistently flared 3-5 shift, even after like 10 revisions from matt
Old 09-23-2015, 06:11 AM
KES08's Avatar
KES08
KES08 is offline
I'm running SRL+ and atlas 40 as well and see 15 city and 17.5-18 hwy. I do have the 3-5 flare every once in awhile but I only seem to get it when in a moderate acceleration from stopped and I let off a bit before it shifts. Seems like sometimes it will do it and other times not too. Love the tune with atlas 40 otherwise
Old 09-23-2015, 08:41 AM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
I run the SRL+ and the economy (that was recommended by both gearhead and Ed) but do not see those numbers. At best on the high way I get 16 mpg and can see as low as 9 in the city. City driving is short runs usually up and down hills.so I cant say these are typical situations. Would love to see better mpgs but have may modifications and do not think they will ever get any better.
Old 09-23-2015, 10:15 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
Have the ability to load another FICM tune yourself?
Old 09-23-2015, 03:41 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
I've run SRL Extreme and the Atlas 80 and saw little to no smoke. It actually runs quite well.
SRL+ and the Atlas 80 netted me 17 mpg on the last tank. The only reason I switched back from SRL Extreme is because I needed to tow something light and didn't want to do it on Extreme. (no more than 5K on SRL+)
Something you need to consider is how and when you load the tune, because thereafter, the truck starts learning.
I.e. If you load the tune on a cold engine, the truck learns how to drive cold first instead of the other way around. This leads to poor performance, poor turbo response, as well as, poor throttle response. Ask me how I know...
Load the tune with the truck up to temp (190 degrees) and then reset the KAM using your SCT or tuning device (most of them can easily do it). This clears completely clears whatever memory the truck has so it builds a new baseline and nothing off of what it had before.
Old 09-23-2015, 07:52 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Extreme and Atlas 40 is pretty darn good, both power and mpg. Your saying you really like Extreme and Atlas 80 together.... hmm, might have to try that. Matt did say that the Atlas 80 will override the commanded fuel of the tune. Maybe that give you good fueling and the other good stuff from the tuner like shifting. .. I love the way it shifts with Extreme loaded!
Old 09-23-2015, 08:03 PM
Toreador_Diesel
Retired Mod
Oddly enough, the atlas 40 was smoky with my truck/strategy and for some reason that combination only leaves a haze and maybe a puff of smoke.
Old 09-23-2015, 08:05 PM
KES08's Avatar
KES08
KES08 is offline
I'd have to say I noticed a pretty big difference on accelerating and throttle response when I loaded the atlas 40 with the SRL+ compared to just running the SRL+ with the stock ficm tune. I even noticed the turbo farting I was getting from the 8k tow tune went away almost completely after loading the atlas 40. Def smokes heavy on hard takeoffs but like you guys said, it clears up pretty quick.
I'm curious now, does the SRL Extreme seem to be a good daily driver or unloaded highway tune?
Old 09-24-2015, 06:57 AM
Toreador_Diesel
Retired Mod
If you can keep your foot out of it, yes...it's an awesome daily driver.
The shifts are nice and solid, but should you need it, there is plenty of power to get around someone or as our previous Governor put it: "Get on down the road".
Its not recommended for towing though, with SRL+ you can get away with 5K max anything above that an it's risky. SRLX is a good, no towing, daily driving tune.
Old 09-24-2015, 07:09 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Interesting you guys mention a 3-5 flare as my SRL bangs into the 2-3 shift.
Atlas 40 is indeed smokey.
Josh
Quick Reply: SLR XXX +Atlas 40 = 16.2mpg in town!
