Red Anti-Freeze - Ford Truck Enthusiasts Forums
Red Anti-Freeze
Old 06-16-2003, 08:53 PM
James Hewett James Hewett is offline
James Hewett is starting off with a positive reputation.
Red Anti-Freeze
I see when I went on tonight, that the new type permanent Red anti-freeze should not be used in engines with aluminun engine parts, is this true and that I must remove it from my 96 T-Bird W/aluminun radiator and other aluminun parts, cause it will damage them????
Old 06-16-2003, 09:06 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Red Anti-Freeze
Quote:
I seriously doubt it, because I've seen at least one GM (the only one I'll touch, my mother-in-law's) with it and it had aluminum heads.
Of course, after it had been in there for 5 years it was truly, really red from all the RUST!
More snake oil, in my opinion...
ak
Old 06-16-2003, 09:15 PM
stephonfan stephonfan is offline
stephonfan is starting off with a positive reputation.
Red Anti-Freeze
All those GM engines like the 2.8 and the 3.1's are aluminum block engines and they use the red dexcool. Maybe fords red coolant is different than dexcool though.
aaron
Old 06-17-2003, 08:31 AM
Red Anti-Freeze
This is some of what it said on the Home page about Hot days and yur Diesel, PG coolant is not recommended for Power Stroke Diesel engines. Because of its chemical makeup, PG coolants can cause damage to aluminum parts, gasket materials and certain kinds of hoses. It also has a lower boiling point than EG coolant, usually 10 F to 15 F lower. While it may not sound like much, in a modern cooling system with a high output engine a few degrees may make all the difference in the world. Coolants that are methyl alcohol or methoxy proponol-based should also never be used. and has me toubled about using(now that it's in there) about long life anti-freeeze.
Thanks for e-zing my mind about PG antifreeze and aluminun.
Radiator paint? Weston67 1967 - 1972 F-100 & Larger F-Series Trucks 5 10-01-2014 02:35 PM
Radiator Help ChuckRob 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-10-2013 01:03 PM
Losin anti-freeze jacksnicky 1987 - 1996 F150 & Larger F-Series Trucks 3 06-11-2011 01:12 PM
Oil in Anti-Freeze Overflow Container searchingforpowe Modular V10 (6.8l) 24 07-06-2005 09:16 PM
aftermarket cooling for a 78 disco truck Deces 1978 - 1996 Big Bronco 4 03-09-2004 10:44 PM
Tags
anti, antifreeze, ford, frees, freeze, hoat, red, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
