cant get my truck to start. - Ford Truck Enthusiasts Forums
Old 09-03-2013, 12:09 PM
Cobra Highboy Cobra Highboy is offline
Cobra Highboy is starting off with a positive reputation.
Hey Guys,
I have searched and cant seem to find the answers im looking for.
I have a 96 PSD straight pipe exhaust, edge evolution, cold air intake, shimmed FPR, and thats about it.
My problem,
I have lost a lot of power (enough that I had to return the computer to stock as it would fall on its face with the programmer in the lowest setting) Had a friend tell me that the HPOP might be going out. I puled the HPOP out and checked it out. the IPR had two out of three o-rings cracked. I replaced them and put the HPOP back in. I removed the fuel bowl to get to the HPOP. while I had the fuel bowl out I checked the FPR and cleaned the FPR screen. I put everything back together and tried to start it with no success. I am thinking I have air in the fuel system but not sure. I checked the DTC's and have no codes at all.
If I do have air in the system how would the best way to bleed it out be?
What else should I check?
I am still learning about Diesel engines so any help is very appreciated.
Old 09-03-2013, 03:53 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Did you refill the HPOP with oil when you replaced it? If not it will take a ot of cranking to refill it. It is best to fill it before crankng. Any time the high pressure oil system is opened up, it will take several 30 second cranking intervals with cool down stops for the starter,to get the engine to fire, and once it is running , up to 50 miles of driving to get all the air out of the system.
Old 09-03-2013, 06:23 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Just keep cranking.
How did you test the hpop ?
Old 09-03-2013, 09:35 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
In case you don't know about this:
http://www.ford-trucks.com/forums/11...rogrammer.html
Old 09-03-2013, 11:53 PM
I did refill the hpop before trying to start it for the first time. I will keep a good charge on the batteries and keep cranking. I will post results in a couple of days. @ old bird 1965, thanks for the link it was very informative. I was actually already thinking about ditching the edge and buying an SCT live wire ts
Old 09-03-2013, 11:55 PM
Any thoughts on the SCT live wire? Is anyone running one? Again thanks for all the help guys. You have never let me down.
Old 09-04-2013, 01:56 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Most of us run a custom tuned ts style chip.
Old 09-04-2013, 08:39 AM
I ran a super chip for a while and it worked just OK. Don't know what a live wire is, must be their newer version. Gabe has it right, get a TS chip, much better.
Old 09-04-2013, 03:16 PM
ok, tuners are the least of my worries right now. since I removed the fuel bowl and drained it am I going to have to bleed the fuel system also or do I just keep cranking on that one too? If I do have to bleed it what is the best way?
Old 09-04-2013, 03:46 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
Just pour some fuel in the bowl and fill it back up.
Old 09-04-2013, 03:48 PM
fordpride's Avatar
Fuel bowl should fill its self.
Your issue could be a failing fuel pump. And it couldn't keep up in a hot tune
Old 09-04-2013, 05:53 PM
I filled the fuel bowl. Fuel pump is new. Sounds like I'm on the right track. Thanks guys.
Old 09-05-2013, 01:02 PM
ok i've been cranking a lot and still not even getting a sputter. could there be something i am still missing? I am about ready to haul it into a shop but dont want to pay some one to fix my truck. the more I fix on it the more I learn about how everything works and the more money I save. Any more Ideas anyone?
Old 09-05-2013, 01:08 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
Check out Nate's No-Start Flow-Chart. its about the best compilation of everything that could cause a no-start that I've seen. its like a choose-your own adventure to help you pinpoint your cause. it even has links to relevant links and things for more info.
it really is quite impressive - and hopefully it helps you out!
http://www.ford-trucks.com/forums/11...flowchart.html
Old 09-05-2013, 02:24 PM
That flow chart is awesome!! I am going to print it and do some more troubleshooting. Thank you so much! You gave me hope again.
HPOP barko4 1999 - 2003 7.3L Power Stroke Diesel 11 02-16-2015 10:47 PM
IPR/ICP? NO START SITUATION.... bike_guy123 1999 - 2003 7.3L Power Stroke Diesel 5 08-27-2014 03:37 PM
urgent - am i missing something - urgent austf350 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-15-2014 07:18 AM
Fuel Overpressure KelVarnson 1999 - 2003 7.3L Power Stroke Diesel 70 09-21-2012 06:10 PM
Solved my low fuel pressure problem kirkharrod 1999 - 2003 7.3L Power Stroke Diesel 11 12-10-2011 07:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
