Fuel treatments? Whats the best for Diesel - Page 2 - Ford Truck Enthusiasts Forums
Old 09-03-2013, 06:55 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
Yep, 4oz of fuel add to full tank of diesel,I use rottella 5w 40 year round with the revx I bought 2 and only used one .good stuff.
Old 09-03-2013, 07:14 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Quote:
Originally Posted by d450heavy View Post
I am running the Rotella 10-30 diesel blend synthetic now, changed the oil about a month ago and now get about 3 miles per gallon more. I drive a lot about 1000 to 1500 miles a week so I am thinking about changing the oil again this weekend and this time using Full Synthetic 5-30 and see if the injectors and hot starts go away. Also will be adding the REV-X to see if it helps the injectors.
I also have heard a few guys using Marine 2 stroke in their trucks. Seems risky but I am new to the whole world of fuel additive thing.
In Oregon we cant get anything but low sulfur Diesel. Not sure of the Cetene rating. We unfortunately live in a state where 90% the people live in one small area and they in turn make the laws and rules for the entire state. And they prefer to ride their bikes to work or drive their smart car. Wear I live everybody drives a truck and most people don't even go visit the towns were the laws are written, so if really doesn't help us out at all.
Any advice on the best Oil to run in the 6.0L manufacture and Weight going into winter? Also how often do you all add the fuel additives, Every fill up?
Yes add fuel additive to every fill up. I don't believe they make a diesel rated 5W-30 engine oil. Most on here like rotella T-6 5W-40. Easily had at Walmart for around 22 bucks a gallon.
Old 09-03-2013, 07:23 PM
Cowboy 65 found it at orilys 5.00 discount make a gallon price 17/18 bucks,find his thread
Old 09-03-2013, 07:30 PM
diesel_dan's Avatar
diesel_dan diesel_dan is online now
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Quote:
I think he might be talking about T5 Rotella? It's a 10W 30 semi-syn HDEO....
Old 09-03-2013, 07:51 PM
This is what I was referring to.
Old 09-03-2013, 10:03 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
I was thinking a little about this one, and this is what I would do. Make sure your FICM has been repaired/updated. If the truck is new to you and your not sure then take your registration(for proof of ownership and VIN#) to the Ford dealer and get a warranty history report. This will list all repairs done under warranty.
If not already done, install the updated blue spring fuel pressure regulator.
Get something that will read live data, like Scan Gauge II.
This is just my opinion, but this would be a good start.
Old 09-03-2013, 10:40 PM
diesel_dan's Avatar
FTE Addict
10-4 Brett, sorry for that...
Old 09-03-2013, 11:26 PM
d450heavy d450heavy is offline
d450heavy is starting off with a positive reputation.
Not sure about the FICM. I did buy the truck new to me about 4 months ago and after buying it had to do some upgrades right away. I did the dummy plugs, new VGT Sensor, New EGR Sensor, Turbo vanes cleaned, Blues Spring upgrade on Fuel line and replaced 2 bad injectors. I also paid the local Ford Dealer to do a Diagnostic test on motor to see what else may need to be done and they only found the 2 bad injectors, and my oil pressure sending unit leaks a little, and my small blue cold air Turbo hose is going bad slowly.
One problem I have had on a very regular basis that I found was the plugs at the FICM would work themselves loose and not allow a restart on hot days. I since used a Zip Tie to hold these in tight and until yesterday when the Zip Tie stretched out a bit it worked great.
I had my FICM Tested for power and all seemed good on computer tests. I am a bit worried as I had an 04 6.0L That had a ton of stuff go bad, too much to mention here and cost about $8K to repair over a few years.
Old 09-08-2013, 06:32 PM
JBSIXGUNS's Avatar
JBSIXGUNS JBSIXGUNS is offline
JBSIXGUNS has a good reputation on FTE.JBSIXGUNS has a good reputation on FTE.JBSIXGUNS has a good reputation on FTE.
I run about 1quart of ashless 2-stroke oil in 25gallons of diesel fuel, I've done it for years, with no problems, it makes a noticeable difference in quieting down my injectors.
Diesel treatment Lonewolftx 6.7L Power Stroke Diesel 5 11-30-2015 05:01 PM
oil treatment flush h20ford 6.0L Power Stroke Diesel 14 05-23-2012 08:51 PM
Memo to TallPaul Valvoline Synpower Oil Treatment Ed Oil & Lubrication 8 11-25-2010 10:57 AM
Prolong Engine Treatment (for oil) and Stanodyne Fuel Treatment... is it good? berick 6.0L Power Stroke Diesel 10 09-04-2010 08:50 PM
Lucas fuel treatment busdriver47 6.0L Power Stroke Diesel 17 11-15-2006 06:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
