Windows wont roll down
The front windows won't roll down in my truck. The driver side doesn't even try to roll down. No movement, no sound from the window motor, nothing. How do I tell if its a bad switch or a bad motor? The wiring is good between the motor and switch and it has good connections that appear clean.
The passenger side window goes down a couple inches and then one side drops down and it stops. If you pick up the one side that drops and press the button it goes down but it's painfully slow.
How do I fix this? This is getting annoying!
Pax window sounds like it's got track issues as well as a motor. Driver's side is probably just a dead motor.
Quick test: probe each motor connector with a meter or test light while pushing window switches. If you find power there, you just need to replace that motor.
Unless you're like me and wouldn't think twice about taking it apart, cleaning up the commutator and checking the brushes, give it a good lube, etc and try again.
pathfindertango
02-20-2015 01:20 PM
fordtough81
10-16-2011 04:38 PM
hugo0612
1999 to 2016 Super Duty
09-17-2007 10:09 PM
