Need a A/C shop that will work on R-12 system. - Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
Old 09-02-2013, 06:40 PM
Mustangking1's Avatar
Mustangking1 Mustangking1 is offline
Mustangking1 is starting off with a positive reputation.
Hello,
Title says it all.
I have a 1978 f250 that needs some a/c work.
I need to find a a/c shop that will work on my r-12 system
If you know of a shop in okc that does r-12 please let me know!
Old 09-08-2013, 03:12 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
If you get a conversion kit, oil and 134 freon, I have a vacuum pump and gauges to evacuate and fill it with 134. I have an R12 can tap, but I don't think it will hook up to my other tools.
Old 09-08-2013, 03:45 PM
What all would I need to replace to convert to r134a?
Old 09-09-2013, 09:31 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Here's a link to one of the stickies in the 80-86 forum and you can see there two links regarding conversion to 134a: Link
Old 09-19-2013, 10:00 PM
The conversion is simply a couple adapter pieces that go on the high and low fittings. You would need those, the proper compressor oil, and freon. Then hopefully the system doesn't leak and functions properly.
Old 09-19-2013, 10:11 PM
I've heard before that you have to replace the drier/orfice tube?
Is the r134a as cold as r-12?
Where can I get the better r134a conversion kits?
Old 09-19-2013, 10:15 PM
Also SwOkcOffRoader do you happen to have the r12 gauges to see whats wrong with my system currently?
Old 09-23-2013, 12:34 AM
The gauges are the same, it's all about the fittings. I have gauges, but would need the fittings. Orifice tubes are inline filters, and cause most ac issues to begin with so yes I'd change it (if there is one) and the dryers are low dollar and can clog up as well. Most parts stores won't warranty compressors unless you buy those at the same time.
Has anyone retrofitted A/C on '93 F150 bf5113x 1987 - 1996 F150 & Larger F-Series Trucks 5 08-05-2015 08:47 AM
Suggestions for A/C Refit? kc5hwb 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-03-2011 02:54 PM
A/C pressures firepop5 1968-2013 Full Size Vans 4 06-21-2009 03:47 PM
91 F-250 A/C Work John with beastly 302 Cooling, Heating, Ventilation & A/C 1 04-22-2009 12:35 AM
Harbor Freight Vacuum Pump fitting that will fit R134A manifold gauge set BigNish 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-20-2002 03:23 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
