F600 dash
So are you thinking a gradual taper down to the dent dash? Sides and top.
It would be cool to have an extra gauge pod to rob some of the dec ribs from and use it on the sides. Somehow use the texture of the gauge panel in the filler panels. Even if it was just a small piece placed within a smooth surface.
Maybe bead roll but that's kinda away from these trucks original personality.
Maybe check out McNichols and see if they have a preformed stamped sheet you could use.
That's a few maybe's for ya.
Alright now I'm into it.....what about using the top of a bump dash with the curve so it would line up at least on top...leaving you to wing it on the sides.
I know there are a few bumps left at my JY and I have a cordless cut off saw. I could look at my CC and see how doable it would be to remove a piece.
f600
I sorta thought that a contored steel top,(mock up),along with even a dent dash pad would not look that unuaual,flat black or stainless,,,that it would mesh smooth into the flat filler plate.,,,to the right maybe nastalgic air billit controls and to the right of the ash tray retro radio,basic am/fm ipod jack,,,,I like the idea of matching ribbed metal,although flat steel all painted up would I think look fine
bryanknie
85
10-16-2022 12:43 AM
grinnergetter
02-22-2017 09:48 PM
joshmillslane
01-18-2003 02:01 PM
