Anyone know of a source to ID various types of six-volt bulbs?
Old 09-02-2013, 04:20 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
Knuckle Bandage Sales Rep
Let me explain what I'm up to....
So I'm getting around to attaching the taillights to my truck bed. They are not stock style lamps...but rather are cool looking and slightly larger ones from the 40's or 50's.
The lamp housing originally had a non-offset single-contact bulb.
I have bought some pigtails that fit into the housing to allow me to run the style of bulbs with two contacts so I can use turn signals.
Here's where I'm looking for help:
I need to find a SIX-VOLT bulb that has non-offset bayonet pins, also with two contact points.
(All I've found for pictures online is the offset pin style)
Anyone have a source for identifying bulb numbers?
Thanks in advance...
Tom
Old 09-02-2013, 04:53 PM
Doc's Avatar
Doc
Doc is offline
I'm on my phone, so I can't look this up to be sure, but I THINK you need an 1158 bulb. Google that and see if I'm right. I ended up buying an offset bulb and VERY carefully knocking one of the two pins off with a grinder. The other pin is still holding it tight enough after about 3 years. I didn't have the patience to find the correct bulb with the even pins.
Old 09-02-2013, 05:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Old 09-02-2013, 05:46 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Originally Posted by ALBUQ F-1
I think the OP in the link deserves some rep points.
Old 09-02-2013, 06:17 PM
pineconeford
Just did all around,
These are available at my local NAPA store too - bonus.
Thanks everyone!
Tom
Old 09-02-2013, 08:59 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Try these for future reference:
http://www.imperialsupplies.com/pdf/...renceChart.pdf
And:
http://vacuumtubes.biz/documents/GE%...%20Catalog.pdf
Two references of transportation bulbs.
Old 09-03-2013, 11:18 AM
pineconeford
Holy smokes Jeremy, that second link has everything anyone would need to know about bulbs!
I did get a laugh out of 'average rated bulb life'. I sure didn't see an asterisk next to that column. It should say that when a bulb is inserted into any trailer application, the rated bulb life instantly becomes 19 hours maximum.
Tom
troverman
2017+ Super Duty
47
12-29-2020 07:19 PM
diamondbackmike2004
2017+ Super Duty
15
01-17-2018 09:26 PM
YoungFordAddict66
05-16-2011 09:13 PM
ztodd377
11-18-2009 11:25 PM
mikedeason
1999 to 2016 Super Duty
05-15-2006 09:21 PM
Quick Reply: Anyone know of a source to ID various types of six-volt bulbs?
