351w transplant
Old 09-02-2013, 04:16 PM
BRay09's Avatar
BRay09
BRay09 is offline
351w transplant
i want to replace the knocking 302 in my bronco with a 351w out of my 96 f250. It is going to be rebuilt and is flat tappet. I am going for low end torque here. Plans for the motor is for it to be bored out and honed, crank polished and a rebuild kit. Crane 444232 camshaft, 1.7RR, full exhaust and MSD ignition.
Heres what i have:
92 bronco 302 with E4OD
33" tires
3.55 ls rear end
I have a complete 96 f250 351w/e4OD parts truck i want to use. Is this a pretty straight forward swap? I know that i need a new y-pipe, but it is getting LT headers on it. What brand of headers fit this bronco best? Emissions arent a problem around these parts, so cat and emissions stuff will be removed.
So what i *think* ineed to do is use the engine harness from the 302 motor and plug it into the 351w computer. Is there anything else i need to watch for? Will the 302 flex plate work with the 351w?
Old 09-02-2013, 04:27 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
96 should be a roller engine.
Old 09-02-2013, 06:20 PM
Conanski's Avatar
Conanski
Conanski is online now
Yes the '96 motor should already have a decent roller cam so just reuse it. No you can't use the 302 flexplate it has 50oz imbalance and the 5.8 has 28oz.
Old 09-02-2013, 08:58 PM
BRay09's Avatar
BRay09
BRay09 is offline
The 96 original engine with 230000was replaced with the one out of the truck in my signature when I put that rebuilt motor in my truck. So it has the small flat tappet cam in it with a new distributor with cast gear on it.
Lil' Bit
03-19-2016 11:27 PM
DManikowski
13
09-13-2012 07:34 PM
IowanStraight6
13
05-03-2011 10:58 AM
joecaley
Engine Swaps
06-10-2005 11:08 AM
jeepsterjayson
08-12-2003 09:29 PM
Quick Reply: 351w transplant
