What is the max bore size for a 272 - Ford Truck Enthusiasts Forums
Old 09-02-2013, 12:24 PM
Rmc292 Rmc292 is offline
Rmc292 is starting off with a positive reputation.
I bought a 272 several years back that had been bored to 3.75 (292) and needs to be bored again. So can anyone tell me the max size that I can take it to or should I have it sleeved?
thx
Old 09-02-2013, 03:46 PM
312 312 is offline
312 is starting off with a positive reputation.
I bored one another .040 but theres always some risk.it is a lot cheaper to buy another block rather than sleeve.
Old 09-03-2013, 10:29 AM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
Have it sonic checked to determine the cylinder wall thickness. If it has to be sleeved, it's time for another block. In my area, all 8 cylinders is about $1200. You can find a few blocks for much less than that.
Old 09-09-2013, 08:48 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
I agree about the cost of sleeving. You can still find 292s. Here's a chart from Ford-Y-blocks; http://www.ford-y-block.com/displacement.htm
Old 09-11-2013, 08:37 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
If you are close to S. Oregon, you can have a good 292 or 272 block for $100.
Max overbore on a 292 69supercj 1957 - 1960 F100 & Larger F-Series Trucks 2 10-21-2013 01:56 PM
Maximum safe overbore for a 292 block 69supercj 1961 - 1966 F-100 & Larger F-Series Trucks 1 10-21-2013 10:27 AM
Rear Main Seal...Same for 239, 272, 292 ??? e william Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 5 06-04-2009 12:21 PM
rear main leaks!! mtford Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 9 11-17-2008 07:45 AM
272 or 292 ? FordFadgeole Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 13 01-04-2004 06:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
