2005 f350 heater / fan motor not working - Ford Truck Enthusiasts Forums
Old 09-02-2013, 01:00 PM
ItsMREMT's Avatar
ItsMREMT ItsMREMT is offline
ItsMREMT is gaining momentum as a positive member of FTE.ItsMREMT is gaining momentum as a positive member of FTE.
Question 2005 f350 heater / fan motor not working
I have a 2005 f350 and the fan motor does not work. I removed my dash to run some audio cables and when I connected it later it stopped work. I did do a search and found this thread but, I do not think its is the fan resistor cause it does not work at any speed.
http://www.ford-trucks.com/forums/10...-suddenly.html
Any thoughts, suggestions, ideas?
AC/Heater Fan quit working suddenly tap1946 1999 to 2016 Super Duty 25 12-29-2015 07:23 AM
1968 / 72 F100/350 A/C & Heater Blower Motor 73/79 Ford L-Series L-model, Louisville Dennis/Ohio Ford Truck Parts for Sale 0 01-17-2014 07:16 AM
Cab fan only works on high? smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 07-20-2010 02:56 PM
2004 F350 PSD 6.0 Clutch fan / AC question mj07469 1999 to 2016 Super Duty 10 10-08-2009 08:47 PM
Need help in the electrical forum Franklin2 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-20-2007 03:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
