1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Actual payload capacity numbers
Old 06-10-2015, 02:48 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Thanks! I don't have any experience with registering according to a weight and was thinking in terms of what is on the door jamb or in the owner's handbook.
Steve
Old 06-10-2015, 11:04 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
Originally Posted by ironman1977
the factory derates axle capacity on purpose, for example a dana 80 has a range from 11-12k, but when you look in door it says 9750, just like front axle it may say 5200-5900 but they are rated at 7000.
The GFAWR and GRAWR are not just dependent on the axles alone. Mounting, springs, wheels, and tires go into that as well. The axle might do just fine with 11,500#, but that doesn't mean much if the hardware holding it to the frame fails...
Old 06-11-2015, 04:12 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Good to keep in mind. Multiple factors can go into ratings other than those that seem obvious.
spleeft
2017+ Super Duty
38
09-20-2018 12:38 PM
beanstock2
11-29-2015 01:29 PM
Shake-N-Bake
EcoBoost (all engine sizes)
07-20-2015 11:52 AM
delornut
2009 - 2014 F150
11-22-2010 02:44 PM
dorsetmerv
05-14-2006 10:36 PM
Quick Reply: Actual payload capacity numbers
