55 F100 AFTERMARKET RADIATOR SUGGESTIONS
Old 08-31-2013, 03:59 PM
ecracer21's Avatar
ecracer21
ecracer21 is offline
hi was wondering if anybody knows of a good aftermarket radiator without spending crazy money..i do not care if it s aluminum or whatever..something thats kind of close to size as the original some modifiation is expected and i do not have a problem with it......the motor is a 223 6 cyl engine...original rad was stolen when i bought the truck so i cant repair that one...it calls for top hose in the center and bottom hose on passenger side...please let me know if you have bought one and maybe have the item or model number..probably going to buy it off ebay seems to be about the best prices...i seen a few for $450-$500 but thats a little steep actually more than i paid for the truck lol...
i just bought a used one but leaks like a siv and all the cores were rotted...this time i am going to buy a new one tired of all the bs..
thanks for your time and hope someone could help me out I sure would appreciate it...
Old 08-31-2013, 06:12 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I don't think you'll find a "good" new one that's also cheap. Did I see another thread from you asking this same question (if not, I apologize). The way it's worded sounds really familiar...
Get a free catalog for Mid Fifties. You'll be spending lots of money with them.
This one is $485 in black with your hose configuration.
Mid Fifty F-100 Parts - Radiators - 4 Row
Old 08-31-2013, 10:27 PM
53OlderThanMe's Avatar
53OlderThanMe
53OlderThanMe is offline
Check here there is a section on radiators.
FAQ
Old 09-01-2013, 06:54 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
I was going to suggest LMC where I bought my replacement - until I noticed that the '53-56 I6 version is almost 2X the cost of the '48-52 version. Didn't realize what a bargain I had until just now.
So a question for the greater FTE, would the '48-52 version work? The radiator configuration is single upper line in with the passenger side return. I'm guessing the shroud would need some tweaks. Are the mounts different?
DW
Old 09-01-2013, 09:25 AM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Do you need a new radiator or a working one? I had a guy give me a 63 f100 that was not running but the radiator looked similar. Maybe you can find one in a wrecking yard.
Old 09-01-2013, 10:49 AM
53FOPAR's Avatar
53FOPAR
53FOPAR is offline
Where are you located? I have a 6 cyl radiator out of a '53. It wasn't leaking at the time it came out but it needs to be cleaned (cored). If you are close enough you can have it cheap.
Old 09-01-2013, 11:27 AM
DR Smith's Avatar
DR Smith
DR Smith is offline
Afco Racing will build you one for about $400 . I had them make me one for my 54 with a 351W . it fit and works fine . Mine is Aluminum .
Old 09-02-2013, 04:41 PM
ecracer21's Avatar
ecracer21
as always thanks alot for all your suggestions and knowledge this site is awesome...i did find one on ebay for $150 shipped to the door it is an aluminum one and had the lower hose on passenger side which i needed and is almost exactly same size and core width as the original...so i will probably have to do a little fabbing but should work well....i wish i had enough money for one of them original looking $800 ones from lmc and also macs but things are tight right now and all that matters to me is the bills are paid for the month everyone is fed and I will have my ol truck on the road hopefully by the end of the month....again thanks for all your replies they are very much apprecited and hope all is well..
Old 09-22-2013, 11:58 AM
NPPollok's Avatar
NPPollok
NPPollok is offline
I got mine off ebay from Superior Radiator in Michigan, which makes them by hand. They're listed on ebay for $350 or best offer. I think I got my for $250. The mounting holes were a little off, but really nice other than that.
Old 09-22-2013, 08:14 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
I'm running a champion aluminum radiator that I purchased from Champion around 220 bucks. It keeps the 351w nice and cool using the stock mechanical fan. The temp stays at around 160 and will warm up to 180 when sitting in traffic.
the only thing I don't like is the trans cooler fittings, not very good at least mine were not. So I purchased a trans cooler.
Old 09-23-2013, 12:52 AM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
I hate to say it but the truck shop in Orange, ca. has a 6 cyl stock type one for $359.
http://www.truckandcarshop.com/
Old 09-23-2013, 04:11 PM
snook715's Avatar
snook715
snook715 is offline
I second Superior and got mine off ebay quite a while ago. I would say they are the way to go.
Old 09-23-2013, 04:17 PM
larryb346's Avatar
larryb346
larryb346 is offline
Mine came from oreilys and was for a mid 70's ford truck and was a bolt in. They have books that will show pictures and give dimensions and you can pick one. Mine is lifetime warranty and was $150 or so. It's for a 302 in a 55 ford but they have about every configeration you can imagine in the books.
Larry
Old 09-24-2013, 06:02 AM
tacson's Avatar
tacson
tacson is offline
Larry
Larry this is the way I was leaning for sourcing a radiator for my 56 project. If you recall can you tell me did you get one for a 302 with automatic and ac? Also be on the lookout for a private message pertaining to dent repair.
Old 09-24-2013, 10:33 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Larry
Have you got a O'Reily parts number? Sure would like to get one.
Quick Reply: 55 F100 AFTERMARKET RADIATOR SUGGESTIONS
