4x4 99 ranger front wheel bearings, how hard? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-31-2013, 03:06 PM
mfp4073's Avatar
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
They are a squeaking and drivin me crazy. how hard are they to do, do they need a press or can they be done at home?
Old 08-31-2013, 04:09 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Here's link on replacing them. If you have a NAPA with a machine shop you could remove the rotors get them checked to see if salvageable and need turned and buy new bearings/seals and have them reinstall and pack them with grease so all you would need to do is reinstall.
| Repair Guides | 4-wheel Drive Front Suspension | Front Wheel Bearings | AutoZone.com
Old 08-31-2013, 05:15 PM
mfp4073's Avatar
I may be wrong about this, but i thought my disks slide right off once the wheel is off?
Old 08-31-2013, 06:04 PM
From what I read it appears they do so you don't need to deal with the rotors. Am used to the 2wd setup and no such luck with them.
Old 08-31-2013, 06:09 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Are you sure it's the wheel bearings that are squeaking?
The '98-'00 4x4 Ranger front hub bearings are not serviceable. You will need to replace the hub/bearing assembly as a whole.
Check out: TRS Magazine - 98-00 Ranger Hub/Bearing Assembly Replacement
IIRC you have also been having issues with the front hubs failing to engage. So you might also consider replacing the original PVH hubs with the AVM manual lockers while you are at it.
Old 08-31-2013, 10:06 PM
mfp4073's Avatar
My 4x4 has never worked. So who knows! I believe the transfer case motor is bad, but also the hoses in the hubs are rotted and the lines corroded!
Old 08-31-2013, 10:50 PM
Rockledge's Avatar
Is the front driveshaft engaging when you switch to 4WD? If the front shaft spins when the truck is in motion and 4WD is selected, then the TC is fine.
All the more reason to abandon the existing vacuum hubs (or modify them to be engaged all the time).
Old 09-01-2013, 10:36 AM
mfp4073's Avatar
I actually have the front drive shaft out right now! But yeah, I dont think its engaging. Been meaning to get around to fixing it, but since I have never really had the need its been on the way way way back burner.
front wheel bearings swampfire79 6.0L Power Stroke Diesel 2 09-26-2012 11:13 PM
C-6 To E4OD conversion MUSKRATT2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 01-25-2012 06:44 PM
2wd to 4wd? ufvj217 Excursion - King of SUVs 7 12-20-2010 04:12 PM
08 expy downshifting hard fairlane66 2007 - 2014 Expedition & Navigator 4 02-21-2010 06:53 PM
ball joints and front u joint on the axle gene17847 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-29-2008 11:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
