Can't clear 0403 code - Ford Truck Enthusiasts Forums
Old 08-31-2013, 12:41 PM
Ken05 Ken05 is offline
Ken05 is starting off with a positive reputation.
My truck recently started throwing up the 0403 code. Double checked my SG2 by clearing it and it shows 4 codes all 0403. Pulled the Egr and it had a fair amount of dry soot on it so I cleaned it and tried again. 0403 still shows up
What is causing multiple (4) 0403 codes. When I cycle thru the code numbers for a brief second it will read 0405 before instantly switching to 0403.
Oil and water temps mirror each other with a few degrees of separation when the trucks been on the road for a while. What am I missing to clear this code or is there something more I need to look into
Old 08-31-2013, 02:23 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
You either have a faulty valve or circuit. 0403 and 0405 are both circuit "A" codes.
Old 08-31-2013, 03:33 PM
How would I fix the circuit problem I do know anything about tracking that down.
Old 08-31-2013, 03:42 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Broken and/or wires that are chafing.
A bad plug can also be a problem.
Time to start chasing wires. Look at each
wire and the harness that it comes from.
clear damage is the easy one. It's the hidden
stuff that will drive you crazy. Feel the wire for
crispy or spongy spots and check there.
Sean
Old 08-31-2013, 03:45 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Its an electrical Problem with the EGR Valve or EGR Electrical Circuit
Have A DVM??
Old 08-31-2013, 05:13 PM
Ok I'm following you now with the circuit , does the egr itself fail or is this just an electrical / plug issue.
Old 08-31-2013, 06:11 PM
BLADE35's Avatar
Quote:
Most common I believe would be the EGR Valve itself failing
Affter that would be wire Harness
P0403 EGR Exhaust Gas Recirculation Control Circuit Open circuit, short to ground or voltage, EGR valve
You can take the DVM and Back Probe the EGR Valve Plug
Here is A WIre diagram
http://www.ford-trucks.com/ford-manu...%20diagram.pdf
Check for the following with engine Running
Vehicle Power 12 volts @ PIN#E
V-REF 5 Volts @ PIN# D
Signal Circuit @ PIN# C
Ground Circuit @ PIN#B
Signal Circuit @ PIN# A
If it don't have all the Circuits working correctly we can get you the PCM Pinout to chase it that way
Old 08-31-2013, 08:29 PM
Thanks very much that will really help
Old 09-01-2013, 10:50 AM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
p0405 is more then often a valve
Old 09-01-2013, 02:39 PM
So I replaced the EgR no luck ,metered the plug and and found the following values
Red- 16.6
Brown- 6.0
Grey w/ orange stripe 0
Grey w/red stripe .06
White .01
What should I do next I'm surprised by the first value since its supposed to be 12 but what does it mean and what should I do next
Old 09-01-2013, 03:23 PM
Yahiko's Avatar
IPR how did we get to that I thought this was an EGR issue.
Sean
Old 09-01-2013, 03:44 PM
Quote:
Sean
Oops EGR to much reading diagrams
Old 09-01-2013, 04:12 PM
Yahiko's Avatar
That's ok. I thought that may of been what happened.
We have alphabet soup with all the acronyms.
Sean
Old 09-01-2013, 09:23 PM
Found the pinpoint test info it looks as if I'm looking for a short to ground or possible a bad PCM.
Wiring is my least favorite thing to do , I'm confused by the language in the diagnostic procedure. I'm kind of guessing at the terminology is what's im assuming below correct
Component side- the egr sensor pins
Harness side - the plug
A little background to how the problem started- I unplugged the Egr and was going to pull it during routine maitenance. Forgot to plug it back in and about a month went bye. Discovered it when I ran a code check and discovered my mistake and pulled the Egr ( grabed the wrong can and cleaned it with brake fluid. Figured I had ruined it so I purchased a new one from advance and installed it. I'm still reading 4 immediate codes all the same a previously posted.
Seems kind of random to Delevop a short but I guess they usally are and I should run through the pinpoint tests and see we're it leads. Anything obvious jump out at anyone I'm missing.
Old 09-01-2013, 11:45 PM
BLADE35's Avatar
Red- 16.6
Brown- 6.0
White .01
Could be the Ground Issue
EGR p0403 2004 Escape hagbard Escape & Escape Hybrid 3 08-13-2016 11:36 AM
No start with codes meetre 6.0L Power Stroke Diesel 11 02-23-2015 10:29 PM
P0405 and P0403 codes lawlor 6.0L Power Stroke Diesel 0 04-30-2014 09:26 AM
Scan Code P-0403/404 kraigwy 6.0L Power Stroke Diesel 5 11-26-2013 08:46 AM
Specific info for P0403 EGR code needed! Psygnosis 1997-2006 Expedition & Navigator 10 06-07-2013 10:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
