Please help diagnose problem
Hey all, my father-in-law has a 1995 E-350 cube van with a 460. The truck runs like crap, pings, and eats fuel like crazy. Pings way harder when cold, like full on rattle!
Van has new plugs, wires, O2 sensors, cleaned out EGR valve of carbon, tried a new ignition module, played with various timing setting. No pinging at 5 degrees retarded, but no power either. Van has 190K Kms and doesn't burn oil at all.
Instead of paying a mechanic to take shots in the dark replacing parts until fixed, looking for ideas or suggestions on what to check for from this knowledgeable group. Thanks in advance for any ideas.
Received 3,102 Likes
on
on
What's a FIL? Don't take another persons word for codes.. most people think that because the check engine light isn't on there are no codes but that's often not the case. You dont need any special tools to pull codes either just a paperclip and pen and paper. The procedure is found here... Fuel Injection Technical Library » How To Run a Self-Test
ogarcia434
09-01-2018 08:46 AM
BrianLaverty
07-19-2013 07:46 PM
LCPullman
15
07-25-2009 12:36 AM
Nathan
11-27-2000 06:03 AM
