I am in the process of installing studs, bp egr cooler, oil cooler and dummy plugs in a 05 F250 and thought I would post some pics along the way. I won't be able to finish it today, because the bp egr cooler won't be here until Tuesday.
I am going to check to be sure, but it should already have it. A diesel shop sold him a new hpop about a hear ago.
Hopefully they added the new fitting with the HPOP.
My previous neighbor had the HPOP go out and took it to the dealer (under warranty). They reused the original STC which we found while doing a stealth delete on the truck. I'm glad and so was my neighbor I decided to pop the HPOP cover to have a look.
You use some sort of 3M disc to clean the surface? Those 3M discs with the rubber "feelers" are great for this.
Only if there is a lot of crud on there. I don't like taking the chance of leaving scratches in the surface, and even the plastic 3m discs can be pretty harsh.
This is an 05 truck and engine, but it had the 04 square standpipe and dummy plugs. I thought that engines with the newer hpop had the allen plugs and standpipes.
....which makes this an EARLY '05 engine, that likely has the EBP mounted to a bracket on top of the thermostat housing, as do earlier engines, and also has a MAF sensor, that later '05 engines don't have.
