HELP!!!
Old 08-31-2013, 09:12 AM
dferrell5's Avatar
dferrell5
dferrell5 is offline
HELP!!!
Trying to figure out or understand what is missing or what the PO did to the truck here. Don't think this gap is normal but need your help to figure it out. Did the PO use front finders from another truck or model year or simply the wrong running boards? Any help would be appreciated.
Old 08-31-2013, 09:28 AM
r_reed's Avatar
r_reed
r_reed is offline
there is a sheet metal panel that covers this spot. if you look through the various pics you will see them. i think i've seen repops in catalogs? or you can prob find used ones fairly easily.
1948 F1dude's Avatar
1948 F1dude
1948 F1dude is offline
<table class="fillwidth" cellspacing="0" cellpadding="2"><tbody><tr><td></td><td><table class="table-order fillwidth" cellspacing="0" cellpadding="5"><tbody><tr><td class="valign-top">7C-16040-PR<input name="pn" type="hidden" value="FL0H7GU91000100"></td><td class="valign-top">Ford Pickup Truck Front Fender Rear Inner Extensions
Macs 1-800-828-1051
</td><td class="valign-top align-left">$15.95 PAIR
</td></tr></tbody></table></td></tr></tbody></table>
Old 08-31-2013, 10:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
dferrell, you appear to have the wrong rubber between your fender and cowl. It should be about 1/2" thick and much wider.
Old 08-31-2013, 05:26 PM
dferrell5's Avatar
dferrell5
One more part
Thank you all for assisting me with identifying the front fender extension I need. Have one more part that is missing that I need help with identifying.
Old 08-31-2013, 05:28 PM
dferrell5's Avatar
dferrell5
One more part
Thank you all for assisting me with identifying the front fender extension I need. Have one more part that is missing that I need help with identifying. What panel is missing that would cover this area? Its missing on both driver and Passenger side. Thanks again everyone.
Old 08-31-2013, 06:23 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Those are the kick panels. They come with the headliner kits like this one from Dennis Carpenter.
Headliner Kit | Dennis Carpenter Ford Restoration Parts
Old 08-31-2013, 08:54 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
They're also available separately.
Old 09-01-2013, 03:06 AM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Gertie-The '49 F2 is offline
The kick panels are made of cardboard (and yes they do last quite a long time as long as they are kept dry), and came in gray, brown, and black. When you order from Carpenter's, make sure when you receive the panels that they also sent the clips that hold them on. When I oredered a new set of panels last year, they were missing the clips. I called Carpenter's, and they cheerfully sent me a set.
Be aware that, at least on my '49 F2, there are three push clips, and one screw and washer per panel. The clips go into the top three holes, and the screw and washer go into the bottom hole. The screw and washer are the same as the ones that hold the healiner in, and is used to prevent the panel bottom from being inadvertantly kicked loose. I noticed that my panels from Carpenter's had only the clips this time around, so I had to reuse my old screws (which was OK, as they were still in good shape).
CUScorpion
2017+ Super Duty
01-17-2019 08:55 PM
351coupe
1947 and Older Ford Trucks
18
01-05-2016 02:49 PM
phg64
09-17-2010 04:07 PM
Fly48
11-23-2005 03:23 AM
sancochojoe
06-22-2004 05:52 AM
Quick Reply: HELP!!!
