5r55e tranny
5r55e tranny
I have a 2001 ranger 4.0L 4x4. The tranny is a 5r55e. My question is: I have been getting a slipping going into 5th gear. It shudders like it doesn't want to go in gear all the way then goes in and drives fine. I also have a leak near the torque converter. anyone else experienced this.
5r55e tranny
Yes, I experienced that on mine. I didn't notice any serious leaks on my truck....but I did experience the slipping going into OD you talk about. I had my transmission "powerflushed" and refilled at my local Ford dealer and it solved my problem. I did this at about 74,000 miles...it was probably the first time it had been done unless the original owner had it done under warranty or something.
5r55e tranny
I also have a 2001 Ranger 4.0w/5r55e. My tranny also shifts just like yours, mine also does it going into 4th. My dealer replaced my tranny at 3000 miles for this problem, but the new one does the exact same thing. When I brought it back to the dealer the service manager brought out a new 2003 fx4 and we went for a ride, guess what, it was even worse than mine! His conclusion is that its normal, but he said he will personally stand behind this tranny for 75,000 miles. Guess I'll have to get that in writing. Other than that I really like this ranger, its even better than the 97 I had before it.
5r55e tranny
One thing you have to watch out for when you have someone flush and fill your tranny is. Are they REALLY using mercon V?
Most use mercon 3 with an additive that susposedly makes it similar to mercon 5. I recommend you goto advance auto and pick up the mercon 5 at 2.49 a quart first.
I dont see how they can make regular mercon 3 which is a conventional atf, similar to mercon 5 which is at least semi-syn.
Rand
Rand
5r55e tranny
It is important to use it Mercon V when specs call for it. Regular Mercon won't cut it.
5r55e tranny
I took the truck in the tech. said this was normal. But correct me in im wrong if you let a tranny slip it bulds up excess heat and shortens its life. Plus my dad has one the same year and his doesn't do this. Can I force the dealer to put a new tranny in or am I just going to have to deal with the slipping.
5r55e tranny
Are you under warranty?
In any case, at least try and make them flush the tranny and make sure they use Mercon V fluid. It just might do the trick.
FWIW, there was a guy a few months ago who posted in the Oil/Lube Forum and he had a Ford dealer flush his 5R55E and they used the WRONG fluid! He had to go back and force them to do the whole thing again. So even the dealer can get the fluids mixed up.
Also, by having the flush done it leaves a paper trail of tranny service which may come in handy later if you continue to experience problems.
Just my 02.
Just my 02.
5r55e tranny
Originally posted by cowboy133
I had it flushed and it didnt help. still slipping. It is still under warranty and the dealer is saying that the slipping is normal. Im getting frustrated.
Just my .02.
