Horse Trailers - Ford Truck Enthusiasts Forums
Horse Trailers
Old 08-30-2013, 04:43 PM
MadogLlewellyn MadogLlewellyn is offline
MadogLlewellyn is starting off with a positive reputation.
Horse Trailers
Anyone of you pull horse trailers with living quarters? Wondering what are my size limits and options? I hear a lot about the heavy tongue weight.... I figured I could pull a 16,000 lb max trailer. No more than 36 -39 ft long overall length. Was looking at a 3 Horse with 14-17 ft living quarters. Do any of you pull that size trailer with a SRW? I see 40ft Toy Haulers pulled by F250s all the time on the highway. Was figuring a horse trailer would be lighter and less drag to pull than those.
I have a 2000 F250 7.3L Crew Cab Flat Bed it was a short bed. Upgrades are; Firestone Airbags rear, Timberlin pads front and back, upgraded leaf springs 2500lbs on each side front axle, 4000lbs each side on rear axle, BF Goodrich 285/75/16E All Terrain rated 3750lb each tire, 4in exhaust with pac brake, 38R turbo, Ford AIS intake, over sized tranny cooler, and intercooler. I figured my truck can handle 12500 lb GVWR with all my mods to the axles and tires. I have it plated for such weight now too. I also have a TS tuner and Edge monitoring system. I know my original truck ratings are way under this. lol.
Old 08-30-2013, 05:14 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
Spend the extra money and get one with a gooseneck and it will tow much better. I pulled a 3 horse gooseneck with qtrs and it rode very well to kentucky and back. It actually rode much better than my 20 ft car hauler bumper pull does.
Old 08-30-2013, 05:27 PM
Dan V Dan V is online now
Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.
Here what I know. I draw the line for a SRW at about 28' on the floor. That's a living quarters trailer. About? you ask? Yeah, depending on how the LQ is finished can really change what they weigh.
Mine, not a true LQ (as it has no bathroom) is 24' on the floor. I can haul 4 head. When I have 4 head in and a bunch of dogs (~8) in roll across the CAT scale at 22k lbs. I'm about 600lbs over on the drive axle, right at the steer axle. Subtract out say, 8000lb, for the truck. That leaves the trailer loaded at 14000lb.
I know people that pull 32' LQ's...and that just isn't right.
I would never try something with a 14'-17' short wall LQ on a SRW...no way.
Toy haulers and RV's are static loads.....Horse are like hauling liquid...the load moves around, and they have a high center of gravity.
Old 08-30-2013, 06:02 PM
I will only be hauling 2x Horse in a 3 horse slant... I would only get a gooseneck trailer... never even thought of a bumper pull... I don't like the way they pull...
But a 14ft LQ with 3 Horse slant has a 28ft floor total 36ft trailer with neck... most of the ones I see run between 9-12k empty... I say 2x Horses and gear is 3000lbs, plus 1000lbs of gear for myself and my son. The trailer should be between 14k and 16k loaded. I know I'd be pushing my limits on tongue weight for the truck.
Old 08-30-2013, 06:33 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I bought a 4-horse bumper pull many years ago. They pull quite nicely.
Stewart
Old 08-30-2013, 06:49 PM
Torklift Sheryl's Avatar
Torklift Sheryl Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
Hi,
With such a heavy load you will want to be cautious if you are having to pump up airbags to the max.
StableLoads allow you to use less air and engage the lower leaf spring overload sooner. We had a recent example too of a 3-Horse trailer with Dressage horses experience an airbag failure and this product got them home.
RV.Net Open Roads Forum: Truck Campers: Picking up new camper...a little advice.
For drivability and safety while towing these make a considerable difference. Stableload_
__________________
Torklift International Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old 08-30-2013, 08:11 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
What an amazingly simple design. Wonder why no one has thought of it sooner? Admittedly, you could build a DIY version, or simply adjust the bump stops for the springs for much cheaper, but for someone who doesn't want to do that, this looks to be a simple, effective solution to help with the loss of sway control caused by adding airbags.
Old 08-31-2013, 11:37 AM
ralleyclimber's Avatar
ralleyclimber ralleyclimber is offline
ralleyclimber is starting off with a positive reputation.
Sounds like a good choice....another thing to add to the list. Anyone here run these?
Old 09-05-2013, 10:54 AM
SPONSOR
Hi,
I wanted to pass along some FTE threads on the StableLoad product in use.
http://www.ford-trucks.com/forums/12...d-install.html
http://www.ford-trucks.com/forums/12...ableloads.html
__________________
Old 09-05-2013, 05:32 PM
Awesome. Thank you.
2001 F250 crew, looking for gooseneck AustMatt 1999 to 2016 Super Duty 16 06-19-2012 11:41 PM
2008 F-250 fifth wheel hitch weight bgathey Fifth Wheel & Gooseneck RV Towing 5 10-06-2011 01:07 PM
Help me help my wife buy a horse trailer. tarantulakeeper1 1987 - 1996 F150 & Larger F-Series Trucks 10 05-22-2011 04:52 PM
Drw bigger tires questions charlessocccer 1987 - 1996 F150 & Larger F-Series Trucks 8 05-08-2011 01:41 PM
Approaching Maximum Weight Ratings sbennett Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 13 11-15-2004 11:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
