help with engine
on
I just found this thread again. Nice solid looking truck. I am so glad you are
going to try and keep the original (or close to it) drive train.
200HP should not be a problem. With better heads, Header, Carb and a later model distributor you should reach that maybe a little more.
Does the 3 speed transmission have an over drive?
Again nice ride, And I like where you are going with the build.
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
In 1969 there was also a 1.23 offered on 302, but unless you can find that exact ID, I suggest forgetting it.
I ran a 1.23 off a 390 on a 289. Saw one on a 302 Mustang, '68 iirc.
Not sure why you think they won't work on a 292. OP may have to fiddle with the choke and maybe rejet, depending on what he finds when he runs it.
Of course, the smaller carb will run cleaner and crisper in the low revs, but the 1.23 isn't like a Holley 500 for drowning the engine.
Am I missing something, or have you tried it and found it to just not "adjust" to the 292?
The 1.23 in '69 came on a Torino, perhaps mustang. They were tuned at the factory for the smaller cars. Yes it will work, but in my opinion not well. It isnt just the engine size, but vehicle. Rich, high idle, slower throttle response in low rpm's, high gas consumption. No I havent tried one of these on a 292. Only have used 1.02, 1.08 and 1.14. I've rebuilt around 100 of the 2100s of all sizes.
Some guys will take something like a 1.21 and adapt them down to a small 6 cylinder, say in the neighborhood of 250 cubes. They love it. But they would love it more if the 2100 was smaller.
These arent very tuneable. A couple jets sizes larger or smaller, adjustment of float level and idle screws, place the accelerator pump rod higher or lower on the lever, that is about all that can be done.
The 292 as far as the carb is concerned, is an air pump, basically the same size as a 289, but known for its torque at low rpms. That can suffer IMHO with the 1.23.
Torque relies upon fuel-air being fed at high velocity. When coming up from idle speed, a smaller bore forces a higher fuel-air velocity for a given displacement. It is better to run a (I suggest vacuum secondary) four barrel with smaller primary bore sizes than a two barrel with larger bore sizes when torque is a concern. This allows the heavy vehicle to get moving without delay. Now, if your engine isn't going to be running high RPM (particularly with a load), a small two barrel will be a great solution. It will provide good fuel mileage and plenty of low RPM torque.
Re-jetting will not solve the loss of low-RPM torque that slow velocity of the fuel-air mixture causes. Main jets really serve best to set cruise-speed mixture ratios. The accelerator pump is what is primarily providing fuel during acceleration.
If you look at the BASE of the carburetor, on the flange, below the 1.23, there is a combination of letters, numbers. That is the ID, and will tell exactly what it was used for originally. Most 1.23s were used on 390 cubic inch engines. A very few in 1969, if I remember correctly, were used on 351s.
thanks again for the comments and contributions, I understand that the carburetor does not work because it is very big for a 292?
I would like to not have to spend a lot now since I have all the restoration ahead. That would be appropriate carburetor.
to see if I'm slowly getting more photos, also I have a post open to the restoration of the bodywork.
https://www.ford-trucks.com/forums/1...ford-f100.html
#30
