Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
new process 435 4 sp info needed..
Old 08-30-2013, 10:31 AM
AVL1955's Avatar
AVL1955
AVL1955 is offline
can anyone tell me if a 435 4sp from an f600 fit in a f350.. have a good one in the f600... bearing howl in the f350..don't want to pull both apart without knowing for sure...thanks
Old 08-30-2013, 01:13 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
Input shaft might be bigger on the F600 model. You can probably compensate with a different pilot and use the F600 clutch disc if you can match it up with the right size pressure plate on your F350.
Bearing retainer might be different as well, read on:
https://www.ford-trucks.com/forums/6...-diameter.html
Does the F600 run or is it a parts truck? If it's a runner, I'd leave it alone and rebuild the F350 trans. Kits, parts more info:
Parts for the New Process 435 Transmission
Old 09-02-2013, 05:51 AM
AVL1955's Avatar
AVL1955
AVL1955 is offline
I have considered a rebuild... kit is approx. 250.00..then to find a competent rebuilder... a factory type reman is 800.00 +... was hoping for a quik swap out... new clutch ***'y ,pilot and flywheel resurface..be done in a day or two..my biggest concern was the trans to bell housing fit... do the holes align correctly.. are the U joint yolks the same size... will the park brake on the back of the f600 fit without major reconstructive surgery... that would be a nice addition to the f350.. all that being said... if it will bolt patterns are the same, I have a 5th over trans in an N model that would be nice in my truck...thanks for the help
Old 09-02-2013, 12:43 PM
85e150's Avatar
85e150
Bell to trans will be the same, the Ford "butterfly" pattern. Input bearing outside diameter, input diameter, input length would be question marks.
Rear housing and output shaft spline would be questions on the other end for the right sized yoke and e-brake set up. I think you'll find the larger truck trans different on both ends.
Old 09-03-2013, 09:33 AM
AVL1955's Avatar
AVL1955
AVL1955 is offline
thanks..going harvesting on thur... taking flywheel, TOB fork. and anything else that is in the neighborhood.. all from a B700 series chassis... have a bunch of these '73 bus' that are minus an engine, parts are easy to pick... i'll start sizing up and measuring...if it looks to be doable, I may take a 5sp from the bus, or the 5th over from the N model.. thanks for the help
Glxy66
07-01-2018 10:43 AM
akguy09
12-20-2015 08:55 AM
DarkOverCast
10-05-2015 12:20 PM
mattsf-100
05-01-2007 06:30 AM
GLPerry
01-19-2002 09:19 PM
Quick Reply: new process 435 4 sp info needed..
