Oil in the turbo hoses - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 08-29-2013, 10:10 PM
dleitzel dleitzel is offline
dleitzel is starting off with a positive reputation.
I have 2013 Ford Explorer Sport with 12k miles. Wife's car and she loves it. The other day the wife comes home and says the car has no power and seems like its a 4 cylinder. No error messages on the dash, but I drove it and she was right no power. I crawled under the car and saw that the post front turbo rubber hose had come off of the plastic tube heading to the top of the engine. Makes sense, no turbo, no power. I reconnected and power returnded. That was simple.
Now the issue, what I noticed when reinstalling the hose was that there was engine oil in the hose. Not a lot but enough to make me concern. Luckily we had an appointment at the dealer already for the fuel tank recall. So we took it in.
The response from the tech was "Small amount of oil found is characteristic of design".
My question is, is this true? Should there be any oil in the air lines? This would be the first turbo I have owned that had any oil in the lines.
Old 08-30-2013, 06:54 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
hose coming off means she was really USING the boost
that and the SLIGHT oil mist is not really anything I would be too concerned about....
Most of my previous turboed vehicles did that a bit too...
Old 08-30-2013, 07:03 AM
Uni-Lightning's Avatar
Uni-Lightning Uni-Lightning is offline
Uni-Lightning is starting off with a positive reputation.
Keep an eye on it for sure. You might have a shaft seal starting to fail. This will allow engine oil in the charge side of the turbo. But with that new of a vehicle it will be covered.
Old 08-30-2013, 12:58 PM
Thanks for the feedback. I will keep an eye on it and yes I suspect my wife keeps the turbo boost pressure up most of the time. She hates to see any of the 365 horses not getting enough exercise. ;-)
Old 09-12-2013, 02:38 PM
03redstx 03redstx is offline
03redstx is starting off with a positive reputation.
I agree if its just a misting, its no biggie...try owning a 26 year old grand National...then we can talk about oil in the hoses
Old 10-07-2013, 04:53 PM
Bananarama Bananarama is offline
Bananarama is gaining momentum as a positive member of FTE.Bananarama is gaining momentum as a positive member of FTE.
interesting item to keep an eye out for. I have 15100 miles on ours. Wife loves to wind up those turbos....as do I
Old 10-10-2013, 08:50 AM
jdadamsjr's Avatar
a screwdriver and 5 minutes is not a bad thing to do to prevent it - just snug them down a bit more and you should be fine... our deezle excursion did that once and it was like OMG, it's a dog, somebody stole half my cylinders
Old 10-11-2013, 03:52 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
Quote:
Or any leaky, noisy twin turbo audi for that matter....
Oil in the tubes is normal. It is likely from the PCV system and not something to worry about.
I have drained in upwards of a pint of oil from a single audi intercooler at one time. Keep an eye on the oil level, any large (one quart or more) amount of oil level change warrants inspection.
Old 10-11-2013, 04:04 AM
On second thought. After owning several single and multiple turbo cars and trucks, you may want to consider the following.
A charge tube blowing off indicates she was on the throttle hard and immediately let off. A couple of conditions can happen here, both of which can be equally as damaging depending on the situation.
In this situation, either the boost diverter valve couldn't keep up with the rush of boost on deceleration and it spiked, or the valve's action was too slow and allowed the spike to happen. Or, the waste gate can stick in the closed position and cause a boost spike on deceleration too. This condition can be worse in comparison as the turbo could produce large amounts of pressure in the engine when the engine isn't prepared to manage the boost resulting catastrophic failure.
I would bring it in and have the codes scanned for an overboost condition or wastegate malfunction.
Old 03-31-2014, 03:09 PM
Chinookman's Avatar
Chinookman Chinookman is offline
Chinookman is starting off with a positive reputation.
GN is a keeper....!
Nice ride ..one of my medic buds @ Benning had one and I would run my puny Suzuki 650 against it..... after initial take off he was gone...lol. but hey it was all fun even sober.......
Old 04-01-2014, 10:10 AM
Quote:
they are fun
Using oil ? B85 1999 - 2003 7.3L Power Stroke Diesel 18 11-09-2015 07:41 AM
Hot air turbo hose calvinbabb 6.0L Power Stroke Diesel 4 07-12-2015 05:46 AM
need help new diesel owner problems with turbo f250jowssh 6.0L Power Stroke Diesel 12 03-25-2015 02:48 AM
oil in turbo air tube? Scurv EcoBoost (all engine sizes) 1 03-24-2014 10:12 PM
Grayish Smoke daddykitty 6.0L Power Stroke Diesel 26 09-14-2013 10:16 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
