Wipers only work on low, won't shut off
Old 08-29-2013, 12:10 PM
1994 f150 4x4's Avatar
1994 f150 4x4
1994 f150 4x4 is offline
Hi everyone,
Recently, my windshield wipers have stopped working as they should.
No matter what speed I set them on, they turn on the what is normally the "low" speed.
If I press the button for the windshield washers, the wipers keep running until I either pull the fuse or stop and remove the key.
The wipers also do not reset to the down position when I turn them off.
I'm guessing this is an issue with the switch since they do move okay. Any thoughts?
Thanks as always for the help.
Old 09-03-2013, 08:42 AM
1994 f150 4x4
Hi again,
Any thoughts on this?
I have searched other threads but am not finding a similar problem.
If I missed a relevant thread can someone point me in the right direction?
Thanks again!
Old 09-03-2013, 09:14 AM
dixie460's Avatar
dixie460
dixie460 is offline
Try this:
https://www.ford-trucks.com/forums/5...-cost-fix.html
If your park switch ain't working, the intermittent wipers will run continuously since the wiper control will never know when to stop the motor.
Old 09-03-2013, 05:52 PM
The Eddie's Avatar
The Eddie
The Eddie is offline
Replace The Intermittent Unit
I ran into this years ago on my '91: simply replace the intermittent unit.
Your dash switch is fine.
Under the dash, follow the dash switch's wiring down. It connects to a black plastic mystery thingy-box, with two male/female connectors. Notice that those two connectors are oriented such that the switch can be connnected such that the mysterious black box can be eliminated from the circuit...and the wipers will work?
Was this Ford's quick way of making intermittent-wiper an option? Remember that these trucks were built when the "X-Files" were on TV...trust no one...
Eddie
Old 09-03-2013, 08:10 PM
1994 f150 4x4
Thank you both.
Will take a look this weekend, unless I have a chance one night this week.
Good to hear that this should be a free / cheap easy fix.
Old 09-05-2013, 05:45 AM
dixie460's Avatar
dixie460
dixie460 is offline
Eddie
Good to know, but the OP has a 94 so it's a different style panel. The wiper controller is on the pax side behind the glovebox on the OBS trucks. Drop the glovebox (open it, squeeze the 2 sides in, pull down) and look just to the right of the opening. There's a small box there and I think it only has 1 harness connector but I could be wrong. That's the wiper controller. When it's working you can hear the output relays click.
EDIT: nevermind I see the OP got his problem fixed and replied in another thread. I'm leaving the info above in case it helps someone when they search.
Old 09-05-2013, 02:55 PM
1994 f150 4x4
Thank you both.
Taking apart the piece on the side of the wiper motor and cleaning it (as the other thread described) worked perfectly.
As a reference for others doing this, I really had to clean the contacts and surrounding area (I used shop rags and carb cleaner) because they were loaded with grease / dirt.
I also had to bend the contacts a lot (almost 90 degrees) before I saw any results.
chillman88
03-31-2017 10:37 AM
jodaddy
10-31-2010 11:16 PM
david00f150
05-24-2009 06:28 PM
giuntoc
02-08-2007 01:15 PM
mirage820
09-19-2004 03:50 PM
Quick Reply: Wipers only work on low, won't shut off
