Running Lights Going out when I turn headlights on - Ford Truck Enthusiasts Forums
Old 08-29-2013, 12:45 PM
oldglory oldglory is offline
oldglory is starting off with a positive reputation.
I have just restored my 1965 ford F-100. I'm having a issue with the running lights. When I pull the head light switch half way to turn them on they work, but when I turn the headlights on they go out. I don't see any wring issues, but my best guess is I have a bad light switch.
Any trouble shooting or suggestions would be greatly appreciated.
Old 11-28-2013, 05:01 PM
ShadowSnowLeopard's Avatar
ShadowSnowLeopard ShadowSnowLeopard is offline
ShadowSnowLeopard is starting off with a positive reputation.
Correct
I am by no means an expert, but my '66 does the same thing. I think I have seen other posts here indicating this is proper. If you find out different please let me know.
Old 11-28-2013, 05:26 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
They didn't have running lights, they are parking lights and not suppose to be on when the headlights are on.
Old 11-28-2013, 05:39 PM
gangstakr's Avatar
gangstakr gangstakr is offline
gangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud of
Quote:
X2 You have no problem.
Old 11-28-2013, 06:45 PM
66f-100's Avatar
66f-100 66f-100 is offline
66f-100 is starting off with a positive reputation.
That's the way the operate but you can change that if you want. If you run a jumper on the headlight switch from the tail lamp circuit to the parking lamp circuit, the parking lamps will be on whenever the tail lights are on.
Old 11-29-2013, 06:35 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
oldglory, It's working like it left the factory. Life was much simpler back then.
John
Old 11-30-2013, 08:24 AM
ddavidv's Avatar
ddavidv ddavidv is offline
ddavidv is gaining momentum as a positive member of FTE.
Replacement headlamp switch will change that. Mine now stay on with the headlamps.
Old 12-02-2013, 02:24 PM
Jon003 Jon003 is offline
Jon003 is starting off with a positive reputation.
I just replaced my switch and mine work the same. This is how the factory set them up to work.
Tail light, Parking light, Running Light, Dash Light Problems 92 Black Nite Electrical Systems/Wiring 200 12-19-2016 06:54 AM
turn signals not working, new headlight switch weblawdog 1957 - 1960 F100 & Larger F-Series Trucks 11 05-15-2015 01:11 AM
Head Light problem Toplait 1987 - 1996 F150 & Larger F-Series Trucks 2 09-12-2013 12:15 AM
auto headlight question TAT2DUP81 1999 to 2016 Super Duty 4 02-24-2011 01:22 PM
Headlight & Instrament Panel light Conflict Neyko Explorer, Sport Trac, Mountaineer & Aviator 2 10-18-1999 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
