High Idle 1990 CA Emissions 5.8
Hi, Bought a F250 4X4 manual tranny with CA smog equipment. As far as I can tell everything is in place and hooked up. Got it cheap and it runs great but burns lots of fuel. Here's the deal. Starts hard when cold. Usually have to crack the throttle plate to get it started. Runs about 1000 rpm until warm, then the idle jumps to 2000 and stays there.
I unplugged the IAC. It dies like it should. Took the IAC solenoid off and I can make it idle wherever I want by moving pintle with my finger.
If I take the vacuum hose off the MAP it will start fine and idle about 650.
No codes or check engine light. What am I dealing with here?
Any help would be appreciated.
Thanks, Bob
Thanks, Bob
