door rattle - Ford Truck Enthusiasts Forums
door rattle
Old 08-28-2013, 09:34 PM
Schickel Schickel is offline
Schickel is starting off with a positive reputation.
door rattle
My driver side door recently started rattling on my 77 regular cab. I've looked at it and I can't find anything loose but when traveling down the road it sounds likethe ddoor is going to fall off. Any suggestions or ideas what it could be and how to fix it?
Old 08-28-2013, 10:15 PM
Broncobobby76 Broncobobby76 is offline
Broncobobby76 is starting off with a positive reputation.
Right now mine is rattling something fierce. It Is the vertical support for the wind wing. I just ordered new door panels from jeffs bronco graveyard, I think when I pull the stock door panel, I will find some loose screws. Could that be what is wrong with yours, or is it the door gasket?
march's Avatar
march march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
There is a plastic cover that goes around the door strike. These often crack and fall off - resulting in the kind of rattle you describe since the remaining post is a smaller diameter. That is what I would check first. Compare it with the other side.
Old 08-28-2013, 10:26 PM
That's a good point
Old 08-29-2013, 06:10 AM
Thanks I will check that out
Door rattle darmento 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-20-2016 08:03 PM
Door rattle quincyj34 1987 - 1996 F150 & Larger F-Series Trucks 18 04-10-2014 08:10 AM
Extended Cab door rattle sagmill 1999 to 2016 Super Duty 15 03-19-2013 02:47 PM
Rattling doors, 97 f150 bkaeding 1997 - 2003 F150 1 04-24-2004 10:26 PM
Misaligned Suicide doors? Supercab rattle wgm114 1999 to 2016 Super Duty 10 04-02-2003 02:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
