Lights ! No lights ?
So I'm making good headway on the restoration of my '49 M-47 Mercury. Got the fenders mounted with the stainless and lights installed. Front grill and lights installed. Everything loose until all the parts are on and everything is okay.
Thougt I'd hook up some wires to check the electrical. Switch to the first notch and yipee . The back lights are on and the front fender lights are on. So I pull to the next notch and the headlights are on. Hit the dimmer and all okay so walk to the front and the fender lights are off. Hmmm...
Back in a notch and they are on and out a notch and headlights on and no fender lights....
Is this the way they are supposed to work on a 6volt all original system ?
Greg M-47
Greg M-47
That's what I was hoping to hear.The Mercury fender lights run off the same wire that would go to the grill lights on the Ford trucks. So guess that they are doing what they should.
Back at the truck thursday. Rear fenders to sand and test fit. And a trip to the tractor shop to search for some 6v bulbs. G-E63 6-8V 3C to be exact.
Thank you for the reply
Greg -47
Greg -47
Most states have laws limiting the number of lamps greater than a certain brightness allowed on the front of vehicle at one time. I suspect that has been around a rather long time. I think that is where the parking light behavior stems from. I expect that is where amber-colored running lamps came from too.
Or, it could all have been due to a wickedly clever patent fight with devilishly sucessful lobbying. But, that would be a conspiracy theory, wouldn't it?
This is for you Allan. I'm going to hook up my signal lights at a later date. For now I'm going all original and scrambling to get my truck ready and safetied so I can get to a friends car show. I promised to show this year and I'm going to even if I have to flatbed it !!
I figured keeping it as simple as possible would make the safety that much easier as less stuff to be checked. I need rear fenders buy may go without the hood if it isn't ready.
Got all winter to work on the signals.
Greg M-47
Greg M-47
