E4OD / 4R100 parts interchange? - Ford Truck Enthusiasts Forums
Old 08-28-2013, 08:38 PM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Here is the deal: I have some parts remaining from my E4OD which were new and never used since I got a rebuilt unit, and I'm interested in selling them locally (I'm in Venezuela, not in the US), and I would like to know if these would work with an 4R100, since that would broaden the possible buyer base. Knowing their prices would be nice too.
- All the seals in the front, including the pump seal and the shaft ring.
- A transmission mount, tagged E7TZ-6068-C.
- A pan in good shape (only replace it because my current pan has a drain).
I'll try to post some pictures later on, thx for the responses guys! .
Old 09-05-2013, 07:22 PM
Encho's Avatar
Anyone wishes to help?.
Old 09-05-2013, 09:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Pans will interchange, but there is a difference between a deep and shallow pan. E4OD used a deep pan in all 4x4 and a shallow pan in all 4x2. 4R100 is more complicated. All 4x4 used the deep pan, and so did 4x2 in '99 and newer Superdutys. Vans and F-150/Expeditions varied. I don't know the rules on those.
Old 09-05-2013, 10:14 PM
Encho's Avatar
What about the seals in the front? are they the same?.
Old 09-05-2013, 11:56 PM
I don't know.
Old 09-14-2013, 11:54 AM
mikeb's66's Avatar
mikeb's66 mikeb's66 is offline
mikeb's66 is gaining momentum as a positive member of FTE.mikeb's66 is gaining momentum as a positive member of FTE.
Pump seal, o-ring and bushing are the same on both transmissions. You could use the pan from an E4OD for a 4R100 if depth is the same, but should probably use correct gasket for the pan as Ford changed gasket in 96, went from cork/neoprene to rubber molded. Earlier pan has raised lines between bolt holes.
Old 09-14-2013, 11:16 PM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
What you have doesn't really carry much of a price tag. $30.00 max.
Any benefits to a larger pan on an E4OD Tranny? hobo99 1987 - 1996 F150 & Larger F-Series Trucks 15 11-11-2016 05:28 PM
4R100 Trans Pan on E4OD Trans Question Inside Man 1987 - 1996 F150 & Larger F-Series Trucks 6 07-28-2016 01:11 PM
E4od/4r100 Mikemusial 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-17-2014 10:43 PM
TRANSMISSION FLUID + FILTER CHANGE clean '97 1994.5 - 1997 7.3L Power Stroke Diesel 1 03-18-2011 03:14 PM
E4OD: shallow or deep pan aurgathor Clutch, Transmission, Differential, Axle & Transfer Case 3 11-28-2008 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
