Ford V10 hard starting - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-28-2013, 08:12 PM
stan'37 stan'37 is offline
stan'37 is starting off with a positive reputation.
My 02 ford V10 is hard starting. If I start it every day, it will start and run well. If I let it sit longer than one day I need to spray some starting fluid to get it to run. I turn the key on and let it pump up before I try to start it. After it starts with starting fluid, and runs for a minute or so it will start up with no problem. Ant thoughts appreciated. Stan
Old 08-28-2013, 08:51 PM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is online now
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
Mileage? Last time plugs were changed? Tune up maintenance records?
Old 08-28-2013, 09:07 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
It could be a lot of things, like a temp sensor not, IAC, weak spark, low fuel pressure, weak battery, vacuum leak or a few dozen other things.
What can you tell us to narrow it down a bit?
Old 08-28-2013, 11:19 PM
The motor has 38,000 mi. Nothing shows up on a scan. It is just the first start. After that it starts like a new one. I changed the fuel filter also. One question should I hear the fuel pump running in the tank all the time? I don't hear the pump running ever, but I drive it after it startes. I would think that would eliminate the pump? Stan
Old 08-29-2013, 05:39 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
My guess would be the IAC(idle air control). Try giving it gas when you try to start it, if it catches I would try cleaning it or replacing it.
Old 08-29-2013, 06:18 AM
redford's Avatar
I would start with a fuel pressure reading.
Old 08-29-2013, 12:04 PM
Wes Tausend Wes Tausend is offline
Wes Tausend is starting off with a positive reputation.
Be careful with the ether.
I second the fuel pressure reading. It's as though a weak pump cannot keep up with the needed extra fuel of a cold start.
Does it lose power loaded heavy, or climbing a long hill under extra throttle?
Wes
Old 08-29-2013, 08:29 PM
I don't like using ether either. I will try using gas in the inlet instead. It doesn't lose power on hills. Thanks for the help. Stan
Old 08-29-2013, 09:04 PM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
try turning the key on and off 5 or 6 times on cold starts
Old 08-29-2013, 09:44 PM
I did turn the key on, and off several times, and it started. what does this mean? Stan
Old 08-29-2013, 10:18 PM
Hotpocket's Avatar
it just primes the fuel system more...kinda like after you install a new fuel filter
Old 08-29-2013, 10:50 PM
So do you think everything is ok? Stan
Old 08-29-2013, 11:19 PM
redford's Avatar
No, that would indicate that you're not getting a full "charge" of fuel when you turn the key on.
As stated earlier, get your fuel pressure measured.
Old 08-29-2013, 11:30 PM
Hotpocket's Avatar
i have somewhat of the same problem...on morning starts i have to crank about twice as long as normal....im thinking my problem is fuel pressure regulator....my truck actually started "choked out" the other morning and i hit the gas a little and it roared to life...if i kill the truck at the gas station i stop at every morning before work...my truck will bog at takeoff...if i let it run while im there it runs fine
Old 08-30-2013, 09:58 AM
I have ordered a complete repair manual. I have been working on motors since the late 50's. Back then things were so simple. These new vehicles make my head hurt. Until my manual arrives, where can I look for the connection to install a pressure gauge? When the key is on, and the pump has charged the system, does it shut off? Stan
Cold, Turn Left Right Front End Noise Stanomatic 1999 to 2016 Super Duty 11 03-14-2016 05:13 PM
New Member in PA sieczkowski351 New Member Introductions 1 01-01-2015 02:05 AM
V 10 eingine oil stan'37 Modular V10 (6.8l) 1 01-10-2014 10:10 PM
02 v 10 still having starting issues stan'37 Modular V10 (6.8l) 3 09-16-2013 09:12 PM
Fuel pressure 02 V10 stan'37 1999 to 2016 Super Duty 5 09-06-2013 10:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
