Will the 6.2 get the job done???
Hey everyone, i'm new to the site and looking for a little info. I currently have a 2010 GMC 1/2 ton with the 6.2 vortec, but i miss my ford so i have been looking at getting another F-250. Due to all the probs i had with my 08 f250 and all the emmission crap on the new diesels, i have been looking at the 250 w/ the 6.2 gasser. My question is, i'm upgrading to a bigger trailer pretty soon and i will be pulling a 3 horse trailer with living quarters and usually 2-3 horses pretty regularly. Will the 6.2 in the 3/4 ton ford get the job done??? Any and all input is welcomed. Thanks
What are you talking... 8,000 pounds? No way a struggle. I'm seeing more and more gassers, including 6.0L Vortec GM powered trucks at campgrounds, and all seem satisfied over the new diesel emission garbage. I considering dumping my 6.4L for a 6.2L soon. I'm done with regenerations and waiting for the 100,000 mile warranty to end on mine.
Not much difference in mpg's but for towing, the 4.30's will give you a little more oomph off the line..
As for the thread posted above, skip to this post:
https://www.ford-trucks.com/forums/1...l#post13443169
This thread, along with a few of the previous meets, has some good reading/videos/info in it:
https://www.ford-trucks.com/forums/1...-hd-video.html
Read of my experience
https://www.ford-trucks.com/forums/1...013-6-2-a.html
You should have no problem with the 6.2 gasser. I have the 4:30 rear, untuned, and performs excellent for my needs. I am having the local exhaust guru install flowmaster 40 dual exhaust on my son's 87' Dodge Ramcharger next week and am considering upgrading the exhaust on the SD. I will post if I go that route. Good luck and welcome to the club.
thanks bullet, from the looks of the video your truck didn't do bad at all. I would be setting my truck up somewhat like yours. How does your truck like the level and 35's? Did that setup take a lot away from it? also, what is the 5 star tuning that I have been seeing a lot of? Is it similar to black bear for GM?
My tires ended up being about 1.5-2" taller than the stock tire, but ironically my speedo is spot on now (gps checked), whereas before it was pretty far off. I think between the tires and the tune (30hp on the 93 tune) that I'm pretty close to the stock power.
