Clutch hardware stackup?
i'm in the home stretch of working up to my ZF swap (I've been talking about it for almost a year now, so darn well better be) and will be ordering the last few parts needed and wanted to check that I had everything covered.
I have a used Single Mass Flywheel (with ring-gear) and Clutch setup already - the clutch is in good shape, but I don't have throwout bearing for it and want to put a new pilot bushing in. there's no other hardware that goes on the tranny input shaft, right?
am I correct that the parts stack-up and order of assembly goes:
1. pilot bearing pressed into flywheel
2. flywheel bolted to crankshaft (after removing flexplate and spacer)
3. clutch and pressure plate bolted to flywheel (clutch aligned with special tool, or extra input shaft in my case)
4. throw-out bearing installed on tranny input shaft
5. clutch fork installed through side of tranny
6. tranny installed onto engine
in the end the throwout bearing rides right against the spring fingers of the pressure plate spring, right?
also, I've seen some Kevlar throwout bearings advertised instead of metal bearing versions. is it worth finding/using one of these?
maybe that's right. I thought it was a while ago that I saw that South Bend (or Valair, maybe) was touting a Kevlar replacement for one of those two. Pilot bearing does make more sense, but I think i'll just go with the stock needlebearing setup. if everything's aligned right, there really shouldn't be much load on that bearing anyway...
thanks guys.
thanks guys.
thanks guys.
thanks guys.
When assembling the clutch, use red locktite on the flywheel and pressure plate bolts. Make sure to use a torque wrench on the flywheel and pressure plate. Check the torque on all the bolts a couple times before moving on to the next step. Just make sure everything is torque correctly and has locktite and it should all work great for you.
If your going to run a Valair clutch, check the flywheel for a brand name. If it's a Valeo, Valair can build you a clutch to fit it IIRC, but their standard clutches are for Luk style flywheels. If it's a Luk flywheel, great, just get one of their clutches, whichever one you wanted. If it's a Valeo, call them and tell them your using a Valeo flywheel.
Eallend7
12-12-2012 05:56 AM
88grandmarquis
26
11-25-2004 02:59 PM
joehar
08-04-2002 02:33 PM
