gear ratios for a F-350 with 6.7 deisel/auto trans
Personally, I think the newer trucks have gear ratios that are numerically quite a bit lower than optimum in order to maximize fuel economy. Running down the freeway empty there may be some validity to this, but I always get the numerically highest gears available. It allows you to better utilize the gear spacing in the transmission and gives you better loaded launch power without generating as much transmission heat. If you're looking at a SRW, 3.55 is the lowest you can get. With a DRW I think its 3.73.
Mitch1407
01-19-2011 11:31 AM
91dirtydiesel
12-19-2008 01:39 AM
eedbl
04-06-2005 01:39 AM
SHUSTANG
02-13-2005 08:58 AM
