need a vin decode please bill or mike - Ford Truck Enthusiasts Forums
Old 08-27-2013, 09:42 PM
spikinfool05's Avatar
spikinfool05 spikinfool05 is offline
spikinfool05 is starting off with a positive reputation.
  • looking at a truck would like the vin decoded please. thank you very much. F26YCF73892
Old 08-27-2013, 10:53 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
F26YCF73892
F26= 4 wheel drive pickup (F250)
Y= 360FE-2V
C= Ontario CAN Assembly Plant
F73892 = This is out of range... 1969 ends at F63,999 and 1970 starts at G30,000 (According to Fordification.com)
Old 08-27-2013, 10:57 PM
Gembone's Avatar
Gembone Gembone is offline
Gembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to behold
My vin decode search brought up this:
Decoding: F26YCF73892
Digit Usage VIN Decoded
1-3 Series F26 F250 4WD pickup
4 Engine Y V8 360-2v 215hp 8.4:1cr
5 Plant C Oakville ON Truck
6-8 Mod Yr/Mfg Date F73 1969 (Mfg Aug 1969)
6-11 Sequential Serial # F73892 F73892
Serial numbers are sequential per plant
Old 08-27-2013, 11:01 PM
thank you folks. anything else a person could get off the door plate that would matter?
Old 08-27-2013, 11:05 PM
HIO Silver's Avatar
Color combo, axle ratio, and trim code!
Old 08-28-2013, 02:47 AM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
Is that a crew by chance as they were built in Ontario?
Old 08-28-2013, 06:49 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
VIN series code of F26 does not decode to 'pickup' until 1973. In fact, no series code of any year F100/350 decodes to pickup until 1973.
VIN series code could apply to any of the following thru 1972: Cab & Chassis, Flareside/Styleside pickups, with factory installed Flat & Stake Beds and as Open Drive-Away Chassis & Cowl and Cowl & Windshield.
1969 F100/750 serial number range: D82,001 - G30,000 (see parts catalog pic).
1966/69 Warranty Plate: 1st line: Warranty Number // 2nd line: W.B. / COLOR / MODEL / BODY / TRANS / AXLE // 3rd line: MAX G.V.W. LBS. / CERT. NET H.P. / RPM / DSO
It's not unusual to find 1968 and later non Crew Cabs that were ordered from, for examples, Atlanta & Pittsburgh to be assembled in Canada.
AFAIK, all 1965/79 Crew Cabs were assembled at the Oakville Ontario Canada Truck Assembly Plant. Today the Edge and its 'rebadged' Lincoln brother are assembled there.
Old 08-28-2013, 07:38 AM
alright thanks bill. so the vin dosent tell me alot then. is the anyway to find out if the truck is orginal with out finding the frame vin?
Old 08-28-2013, 07:42 AM
Quote:
Originally Posted by spikinfool05 View Post
alright thanks bill, so the VIN doesn't tell me alot then. Is there any way to find out if the truck is original without finding the frame VIN?
Compare the VIN (Warranty Number) stamped on the Warranty Plate to the VIN on the title/registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
If the VIN's match, post all the codes stamped on the Warranty Plate.
Old 08-28-2013, 07:44 AM
ok as always thank you sir for your help.
Old 08-28-2013, 11:21 AM
jons72 jons72 is offline
jons72 is starting off with a positive reputation.
lmc
if you get a lmc truck catalog it will help you decode your truck, you can also look at it on there website lmctruck.com
Old 08-28-2013, 03:31 PM
Sim1979F100 Sim1979F100 is offline
Sim1979F100 is starting off with a positive reputation.
NEED HELP Please
NumberDummy please help! I am in the middle of a power brake conversion on my 1979 F100, manual brake, manual transmission, no cruise. Having a hard time locating the pedal that is needed. Can you help in any way? Have one lead but it might be a dead end. Any help is much appreciated.
Old 08-28-2013, 06:10 PM
Quote:
The brake pedal has to match the booster. What is the booster from?
Old 08-28-2013, 08:50 PM
Quote:
LMC's VIN's decoders aren't worth TWO CENTS, have a gazillion errors and omissions.
Old 08-28-2013, 10:00 PM
Quote:
Bought it online A1 Cardone brake booster with master Cylinder from OREILLY's Auto Parts. Bought bracket on ebay. Everything fits great. Needs the right pedal now. Just can't locate one. Is modifing the one I got or the booster an option?
1947 Vin Decode Jeffsuch 1947 and Older Ford Trucks 3 09-25-2015 06:47 PM
vin decoder seohwash Large Truck 2 06-24-2015 06:24 PM
1967 F600 VIN DECODE Ross Carl 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-24-2015 07:44 PM
Vin help offroadaddiction 1961 - 1963 F100 Unibody 1 07-21-2014 11:26 AM
Ford VIN carllouis 1997-2006 Expedition & Navigator 1 06-15-2000 02:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
